درخواست: فرستنده ها و گيرنده
jfrras
مدير انجمن تخصصی الکترونیک
3,180
74,241
49
با تشکر از پاسخ شما.بله در جریان هستم که استفاده از فرستنده های دوربرد مجوز میخواد.لطفا نقشه یه فرستنده مناسب که ساخت اون خیلیم دشوار نباشه رو واسم قرار بدین.من شنیدم به ازای هر 1 وات قدرت می شه 1 کیلومتر رو برد فرستنده حساب باز کرد با این وجود یه فرستنده 10 تا 15 وات جوابگوی نیاز من خواهد بود.لطفا راهنمایی کنید
دوست عزیز طبق تجربه این مدار با آنتن مناسب میتون 10 تا 15 رو جواب بده . این مدار جنبه آموزشی داره و مسئولیت ساختش بعهده سازنده میباشد.!!!!!
= FM TRANSMITTER 3 - 3.5 W =
This package contains the schematic for an FM transmitter with 3 to 3.5 W output power, and can be used between 90 and 110 Mhz. Although the stability Although the stability isn't so bad, a PLL can be used on this circuit.
This is a circuit that I've build a few years ago for a friend, who used it in combination with the BLY88 amplifier to obtain 20 W output power (for that schematic, get the LINBLY88.EXE file). From the notes that I made at the original schematic, it worked fine with a SWR of 1 : 1.05 (quite normal at my place with my antenna). He didn't use it for stereo broadcasting, but that shouldn't be a problem.
BTW: I'm sorry about the mess my OrCAD Annotate made of the component numbers.
2) Components/Hints
I don't have a PCB-layout for it, but as I remember I've made it on a normal RF-testing breadboard (with one side copper). Make some connections between the two sides. Build the transmitter in a RF-proof casing, use good connectors and cable, make a shielding between the different stages, and be aware of all the other RF-rules of building.
Q1 and Q5 should be cooled with a heatsink. The case-pin of Q4 should be grounded.
Adjustments:
C24 is for the frequency adjustment. The other trimmers must be adjusted to maximum output power with minimum SWR and input current
[hide]
[/hide]
Component list of the 3 - 3.5 W FM transmitter (Type 1)
Resistors:
(All resistors are 1/4 W carbon or metalfilm types)
R1 : 10k R6 : 680E R11: 680E R2 : 22k R7 : 150E R12: 100E R3 : 22k R8 : 100E R13: 3.9k R4 : 10k R9 : 68E R14: 10k R5 : 3.9k R10: 6.8k R15: 10k Capacitors:
C1 : 4.7 pF ceramic C11: 100 nF ceramic C21: 40 pF trimmer C2 : 100 nF ceramic C12: 100 nF ceramic C22: 40 pF trimmer C3 : 100 nF ceramic C13: 82 pF ceramic C23: 40 pF trimmer C4 : 100 nF ceramic C14: 60 pF trimmer C24: 40 pF trimmer C5 : 100 nF ceramic C15: 27 pF ceramic C25: 5 pF ceramic C6 : 10 nF ceramic C16: 22 pF ceramic C7 : 100 nF ceramic C17: 10 uF/25V C8 : 60 pF trimmer C18: 33 pF ceramic C9 : 10 nF ceramic C19: 18 pF ceramic C10: 10 nF ceramic C20: 12 pF ceramic Inductors:
L1 : 5 wdg, dia 6 mm, 1 mm CuAg, space 1 mm L2 : 6-hole ferroxcube wideband HF-choke (5 wdg) L3 : 6-hole ferroxcube wideband HF-choke (5 wdg) L4 : 1.5 wdg, dia 6 mm, 1 mm CuAg, space 1 mm L5 : 6-hole ferroxcube wideband HF-choke (5 wdg) L6 : 1.5 wdg, dia 6 mm, 1 mm CuAg, space 1 mm L7 : 6-hole ferroxcube wideband HF-choke (5 wdg) L8 : 1.5 wdg, dia 6 mm, 1 mm CuAg, space 1 mm L9 : 6-hole ferroxcube wideband HF-choke (5 wdg) L10: 8 wdg, dia 5 mm, 1 mm CuAg, space 1 mm Transistors:
Q1 : 2N3866 Q2 : 2N2219A Q3 : BF115 Q4 : 2N2219A Q5 : 2N3553 Others:
D1 : BB405, BB102 or equal (most varicaps with C = 2-20 pF (approx) will do)
U1 : uA78L08, uA7809, uA7810 or equal (MC78LXX, UC78LXX etc)
2elyas
407
1,559
سلام دوست عزیزم آقای 2elyas
دستت درد نکنه . تشکر
idden content may not be quoted
اینهم نمونه که قبلا گفته بودم.
سلام استاد .جدا دمتون گرم ایشا الله زنده باشی و سلامت که بنده و تمام دوستان بتونیم از تجربه های شما استفاده کنیم تنها کاری هم که از دست ما برمیاد دعا برای سلامتی و موفقیت روز افزون شماست: راستی استاد دقت تغییراتش چقده ؟ یعنی مقدار فرکانسی که میشه با up down تغییر داد ]چه اندازه ایه؟ حالا میشه این مدار رو از شما خرید؟لطف کنید بگید قیمتش چقدره تا در صورت احتیاج بنده ودوستان بتونن تهیه کنن.راجع به اون سینتی سایزری هم که خدمتتون عرض کردم اگه مدار ی با کیفیت بالا گیرتون اومد بنده رو حتما در جریان بذارید.بازم کمال تشکر رو از شما وتمام زحمتکشان ایران تیکا دارم .:68000000:بدرود استاد.
jfrras
3,180
74,241
49
سلامت باشی و همچنین با آرزوی موفقیت برای شما .
محدوده 60 تا 1300 مگاهرتز . با استپ های 50 کیلوهرتز . 100 کیلوهرتز . 1 مگاهرتز و 10 مگاهرتز .
راجع به فروش این مدار فعلا تصمیمی نگرفته ام .نزدیک 2 ماه روش کار کرده ام. و فعلا قصد فروش ندارم .
چشم . گیرنده یا فرستند ه اش رو داری ؟ تا قفل کننده ثابت بهت بدم!
2elyas
407
1,559
با درود : آره گیرنده و فرستندشو دارم .واقعا ممنونم از جنابعالی .فقط توی این گیرنده فرستنده از کریستال استفاده شده میخوام اگه بشه به کمک شما با یه سینتی فرکانسشو قابل تغییر کنم حیطه فرکانسیشم از 200تا 260 مگا هرتز باشه . ایشالله میشه که؟
واکنش‌ها[ی پسندها]: jfrras
jfrras
3,180
74,241
49
نقشه مدار رو داری ؟ تا قسمت ارتباط کریستال ها رو بررسی کنم. انشاالله اگه وقت شد روی نرم افزارش کار کنیم ببینیم چی میشه . آخه چندتا پروژه دارم باید روشون کار کنم. و با کارای مغازه تقریبا وقت خیلی کمه. چرا نمی خوای روی فرکانس دیگه ای کار کنی؟ چرا این فرکانس براتون مهمه؟
sina.vd
8
2) Components/Hints
Adjustments:
Resistors:
بسیار سپاسگزارم از توجه شما.اما با توجه به تجربه اندک بنده کمی گنگه واسم.اگه خودتون قبلا براش pcb زدین قرار بدین که پروسه مونتاژش برام راحتتر بشه.یعنی اگه 3.5 وات 10 کیلومتر برد داشته باشه 18 وات طبیعتا بالای 30 کیلومتر برد داره ؟!
واکنش‌ها[ی پسندها]: 2elyas
jfrras
3,180
74,241
49
دوست عزیز باید طراحی پی سی بی رو هم یاد بگیری . من این مدا رونزدم .پی سی بیش رو ندارم . بله 4 وات حدود 15 کیلومتر شاید بیشتر هم بود . خیلی از عوامل در برد فرستنده تاثیر داره یکیش آنتن مناسبه دومیش تغذیه صاف .استفاده از کابل مرغوب . از همه مهمتر قطعات مرغوب است .
موفق باشید.
2elyas
407
1,559
سلام و درود :نقشه مدار رو ندارم استاد این مدارو یکی از دوستان تهیه کرده که الان ایران نیست.اصلا راضی نیستم که خدایی نکرده خللی تو کارای دیگتون ایجاد بشه همینکه همین وقت رو هم برای این حقیر گذاشتی بینهایت سپاس گذارم.سازنده این مدار میگفت حیطه فرکانسیشو تو این رنج میتونی تغییر بدی البته با تغییرات اندازه آنتنش .
as3
توي يكي از فروم ها تاكي واكي با مدول rfm12bp ديدم اگه كسي نقشه و اطلاعات فني داره بگه ممنون ميشم
farzad_LG
44
257
با سلام خدمت اساتید عزیز نمیدونم محل سوال من درست است یا خیر من طرح یک مدار فرستنده و گیرنده رادیوی ساده برای قطع و وصل کردن یک رله میخواستم البته اگر بردش تا 2 الی 3 متر هم بود مشکلی نیست کار من را راه می اندازد فقط مثل دزد گیر ماشین یک فرمان قطع و یک فرمان وصل ممنون می شوم اگر لطف کنید
