سوال: شناسایی این قطعه
abbas136824
660
5,574
سلام یکی از دوستان این قطعه که عکسشو گذاشتم واسم اورد میشه رااهنمایی کنید این قطعه چیه وبدرد چه کاری میخوره؟
مشاهده فایل‌پیوست 2
reza_476
4,007
45,330
به فایل زیر مراجعه کن :
[hide]
Convert your SATA/ IDE hard drive into an external USB drive -
ideal for backup and service!
USB 3.0 adapter cable for fast and easy HDD
connections - no external enclosure needed. Use any
2.5 / 3.5 IDE hard drive or SATA hard disk as an
additional external hard drive. Ideal for service,
maintenance, hassle-free temporary HDD access, e.
g. for data backups and restore purposes.
•Supports 2.5/3.5 IDE and SATA HDDs
•Supported data transfer rates: Super-Speed (5Gbps),
High-Speed (480Mbps), Full-Speed (12Mbps) and Low-
Speed (1.5Mbps)
•Supports SATA 1.5 Gbps /3.0 Gbps speed negotiation
•Compliant to Universal Serial Bus 3.0 specification,
downwards compatible to USB 2.0, 1.1 specification
•Compliance with USB Mass Storage Class
•Plug & play and hot-swappable
•incl. power supply 12V/2A
•Compliant to Serial ATA2.6
PACKAGE CONTENT
•USB 3.0 IDE & SATA cable
•3.5" to 2.5" adapter
•4Pin - power cable
•Power supply 12V / 2A
[/hide]
  • 26.8 کیلوبایت بازدیدها: 74
