Elektors Components Database 5
mahdimbayat
1387٫12٫25
27
74
Completely updated!
TIP: Order this CD-ROM along with other Elektor products and get FREE P&P on the whole order!
The program package consists of eight databanks covering ICs, transistors, diodes and optocouplers. A further eleven applications cover the calculation of, for example, zener diode series resistors, voltage regulators, voltage dividers and AMV’s. A colour band decoder is included for determining resistor and inductor values.
Each databank contains the following on (almost) any component: enclosure drawing, pin connections, technical data (as far as known). Also included is a search engine acting on user supplied parameters. The ECD gives you easy access to design data for over 5,400 ICs, more than 35,800 transistors, FETs, thyristors and triacs, just under 25,000 diodes and 1,800 optocouplers.
All databank applications are fully interactive, allowing the user to add, edit and complete component data. This CD-ROM is a must-have for all electronics enthusiasts!
New features:
- Accelerated parameter search
- Optimized search options
- Retrieve additional data with all components
- Enter user notes with all components
- Direct links to equivalent types
- New layout
http://rapidshare.com/files/274648233/CD3.rar.html
Password: sonsivri.com
