دوست علم و صنعتی محترم اول برو به سایت
Fluke 287 and 289 Multimeter Firmware Update
بعد اینا رو ببین
[h=1]Fluke 287 and 289 Multimeter Firmware Update[/h]
Fluke 287 Firmware update version 1.16
To upgrade your 287 to the latest firmware, follow these simple instructions:
- Click this link to download and save the firmware upgrade file.
- Ensure your Fluke 287 is connected to your computer using your Fluke USB-IR serial cable and run the file.
Version 1.16 corrects an issue where recording sessions could be interrupted or terminated when using the record function in combination with ambient conditions of bright sunlight or other sources of bright light, when used without the IR cable attached.
Version 1.16 does not apply for units labeled 287/TPWS or 287/NUC.
Software licensing information that is required for the open-source software used is available
here.
وقتی کارت تموم شد با دو دست و بصورت فوقالعاده محکم بکوب رو دکمه تشکر
یا حق
