چرا سیستم من این پیغام را میدهد
hojjatdavoud
92
427
47
گرمی
سلام من یه سیستم تازه خریدم موقعی که با اینترنت اکسپلورر کار میکنم در هنگام ورود به صفحات https این پیغام را میده و یاهو مسنجر هم کار نمیکنه یعنی لاگ این نمیشه
[h=1]There is a problem with this website's security certificate.[/h]
[h=3]
[/h]
[h=3]
The security certificate presented by this website has expired or is not yet valid.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.[/h]
[h=2]We recommend that you close this webpage and do not continue to this website. [/h]
[h=4]
Click here to close this webpage.[/h]
[h=4]
Continue to this website (not recommended).[/h]
[h=4]
More information
[/h]
If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting. When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com. For more information, see "Certificate Errors" in Internet Explorer Help.
