نرم افزار ویرایش فایلهای sis (ورژن جدید) Sis editor v0.51 En
6,774
29,828
Sis editor v0.51 En
A mobile side sis / sisx files unpacked and packaged software, are quite large gong! The biggest feature is support for sis / sisx packages editing, even if packaged very complicated way of sis / sisx packages can also be easily edited and intact! Has not yet been found to be unable to edit sis / sisx packages! Let us look at the specific features of this software:
1, support editing sis / sisx file basic information, such as program name, uid, created, program version, provider name, language, target device, the type of installation and so on.
2, support editing sis / sisx file list, including the program components can also be edited.
3, support the new sis / sisx packages. This feature is still at a basic level, the future will be perfect.
4, can be sis / sisx package inside the file the following: add, delete, replace, extract, property editing (can be four kinds of operation), moved up and down, etc.
5, support cross-screen operation, you can better see the specific path of the file.
6, the program language support, added 100. Goal-setting support for all third and fifth edition of the model selection. Support 5 kinds of the type of installation.
7, support the sis / sisx file unpack the theme and packaging
Note: The edit and save the sis / sisx packages, need to sign to install.
Version 0.51 update:
- Accelerated the pace of preservation, especially in the MR models to better reflect the
- Reduce the installation files from the original 78kb down to 55kb now
- Solved the creation date of a BUG
Follow-up version of the function to be developed:
1, the file signature and remove the signature
2, the new sis / sisx package bulk import feature
3, the entire folder unpack function of bulk
4, other more anticipated features ...
