نرم افزار امنیتی برای تعیین زمان قفل در پروفایلها
6,774
29,828
Mr. Lock description
Set the idle period after which to autolock the keypad, enable autolock on a profile/application basis.
# You can set the idle period after which Mr Lock will autolock the keypad.
# You can also define the profiles in which Mr Lock will be enabled.
# And last but not least, you can ask him not to lock the keypad when you are running a particular application.
Requirements:
· Symbian S60 3rd edition
