آموزشی: ایمیج گیری از هارد های بدسکتور با برنامه قدرتمند Clonezilla Live 2.3.1.-18
pese
257
1,549
www.servicekaran.ir
این برنامه بوتیبل می باشد و ساخت کشور تایوان است و بسیار قدرتمند است.
دانلود برنامه در لینک زیر با حجم 160 مگا بایت
http://files01.techspot.com/temp/clonezilla-live-2.3.1-18-i586.iso
[h=2]CloneZilla Server Edition[/h]
سایت سازنده:
[h=3]1. About Clonezilla Live[/h]
Clonezilla Live is a small bootable GNU/Linux distribution for x86/amd64 (x86-64) based computers. Clonezilla SE (Server Edition) has been developed from 2004, and it is used to deploy many computers simultaneously. It is an extremely useful tool, however, it does have several limitations. In order to use it, you must first prepare a DRBL server AND the machine to be deployed must boot from a network (e.g. PXE/iPXE). To address these limitations, we have combined Debian Live with Clonezilla as "Clonezilla Live," a software that can be used to easily image and clone individual machines. The primary benefit of Clonezilla Live is that it eliminates the need to set up a DRBL server ahead of time and the need for the computer being deployed to boot from a network. Clonezilla Live can be used to image or clone individual computers using a CD/DVD or USB flash drive. Though the image size is limited by the boot media's storage capacity, this problem can be eliminated by using a network filesystem such as sshfs or samba.
[h=3]2. How to install Clonezilla Live ?[/h]
To install Clonezilla live, the basic steps are to download pre-build Clonezilla Live then put it in a boot media (CD, USB flash drive or USB hard drive). Two types of files are available, iso and zip. The former one is for CD, the latter is for USB flash drive. Besides, you can put Clonezilla live on hard drive or PXE server, too.
  • For CD/DVD:
  • For USB flash drive or USB hard drive:
    • To put Clonezilla live on a USB flash drive or USB hard drive, check this doc.
  • For hard drive:
    • To put Clonezilla live on a harddrive with OS installed already, check this doc.
  • For PXE server:
    • To put Clonezilla live on a PXE server and boot your client via PXE, check this doc.
If you are interested in creating the Clonezilla live iso or zip file from scratch, check this doc. //New for creating Clonezilla live 2.x!//
[h=3]3. How to use Clonezilla live ?[/h]
Please refer to this doc for more details.​
[h=3]4. Accounts[/h]
In Clonezilla live, two accounts are available: (1) account "user" with sudo privilege, password is "live", (2) administration account "root", no password. Therefore you can not login as root, the only way to get root privilege is to login as user, and run "sudo -i" or "sudo su -" to become root.
For better security, it is recommended to change the passwords of user and root by command "passwd" before you allow remote access. When Clonezilla live boots, the ssh service is NOT automatically started, and the setting in /etc/hosts.deny does NOT block any connection. If you want to remotely ssh login into your Clonezilla live, you have to start ssh service by "service ssh start".
[h=3]5. Advanced modes[/h] Some advanced modes are available:
Clonezilla live
ali8889
447
1,823
با تشکر از مطلب خوبتون بعد از ایمیج گرفتن با چه نرم افزاری میشه ایمیج باز کرد و با چه نرم افزاری میشه ایمیج ریکاوری کرد
pese
257
1,549
www.servicekaran.ir
Clonezilla: Clone كردن مجاني هارد نويسنده: Christian Lanzerath
مترجم: وهاب حاجي باقري
آيا هارد شما سرو صداي اضافي كرده و مشكلاتي را از خود نشان مي‌دهد؟ پس كار مهم اين است كه قبل از ازبین رفتن تمامي داده‌ها، هارد جديدي را تهيه كنيد. Chip Online به شما نشان خواهد داد كه چگونه مي‌توانيد به راحتي و مجانا هارد خود را Cloneكنيد. لنگه‌اي از هارد براي مقابله با از بين رفتن داده‌ها اگر در نزديكي زمان وقوع Crash در هاردتان به سر مي‌بريد، بايد سرعت عمل به خرج دهيد با كمك Clonezilla كه به صورت مجاني در نسخه‌هاي لينوكس قرار دارد و قابل دانلود نيز هست مي‌توانيد در سريعترين زمان و بدون احتياج به تنظيمات زياد يك كپي 1:1 از هارد به اضافه تمامي پارتیشن ها و فايل‌های موجود ويندوز انجام دهيد. سپس بايد Clone را در هارد جديدي از حالت فشرده خارج ساخته و به كارتان ادامه دهيد. انگار نه انگار كه مشكلي وجود داشته است. در هنگام جابجايي، اين نرم‌افزار بسيار عالي است. اگر هارد قديميتان ديگر فضايي ندارد، با توجه به كمك‌هاي اين نرم‌افزار به راحتي مي‌توانيد جابجايي به هاردي با فضاي بيشتر را عملي كنيد.
علائم وجود مشكل در هارد علائم زيادي وجود دارند كه نشانگر مشكل‌دار بودن هارد مي‌باشند. براي مثال هنگامي كه هارد شروع به دادن صداهاي اضافي ياخش‌خش مي‌كند، ديگر اطميناني به آن نيست. از جمله مثال‌هاي ديگر مي‌تواند، Crash كردن مدام ويندوز، ذخيره نادرست فايل‌ها و يا مشكل در كپي كردن آنها، نشان دادن صفحه آبي در حين شروع و تقاضاي هر باره به چك كردن مشكلات باشد. البته در ابتدا بايد با نرم‌افزارهايي همچو HDD Health از وجود و چگونگي و نوع مشكلات آگاه شده و يقين پيدا كنيد. اين برنامه ارزش‌هاي SMART هارد را مي‌خواند. عبارت SMART اختصاري از self-Monitoring, Analysis and reporting technology مي‌باشد كه مسئول نگهباني سلامت هارد مي‌باشد. رايت كردن Live-CD و شروع Clonezilla يك live –System است اين بدين معنا ست كه شما كامپيوتر را مستقيما از سي‌دي‌ بوت مي‌كنيد. مزيت: احتياج به نصب نرم‌افزار بر روي هاردي كه به هر حال مشكل‌دار شده است را نداريد.
ساخت Boot-CD: Clonezilla-ISO-Image را دانلود كنيد و بر روي يك سي‌دي آن را رايت كنيد. البته براي اين كار بايد در nero گزينه رايت يك Image را برگزينيد. اينكه فايل ISO را به راحتي بر روي سي‌دي بريزيد مشكلي را از شما حل نمي‌كند. اگر از Nero استفاده نمي‌كنيد، مي‌توانيد از نرم‌افزار مجاني imgburn استفاده كنيد. در اينجا بايد گزينه write image file to disc را كليك كرده و سپس فايل ISO مربوط را انتخاب و به دستورات نرم افزار گوش كنيد. تنها پس از چند دقيقه Clonezilla كه داراي 85 مگابايت محتوا مي‌باشد رايت شده و آماده شروع است. شروع Clonezilla: سي‌دي را در درايو گذاشته و كامپيوتر را restart كنيد به اين امر توجه كنيد كه كامپيوتر از طريق سي‌دي بوت شود. براي اين كار بايد در بايوس كه توسط دگمه [F2] يا [delete] در حين بالا آمدن كامپيوتر قابل دسترسي است، ترتيب بوت را تغيير دهيد. اين گزينه نيز اكثرا در منوي Boot واقع شده است. درايو مربوط به CD/DVD را در جايگاه اول قرار دهيد. اكنون كامپيوتر از طريق سي‌دي بوت شده و Clonezilla را به سرعت فعال مي‌كند. ساخت Image، Clone با قدمي مياني Clonezilla براي كپي كردن هارد، دو راه را عرضه مي‌كند: متد Image محتواي هارد را تنها در چندين فايل بر روي يك هارد USB ذخيره مي‌كند. اين مسئله زماني به درد خورد و مزيت بالايي را دارا است كه هنوز هارد داخلي جديدي را تهيه نكرده باشيد. شروع Clonezilla : ابتدا بايد كيفيت تصوير را انتخاب كرد: قدم‌هاي اول پس از شروع Clonezilla از طريق سي‌دي با سه گزينه براي شروع برخورد خواهيد كرد. اين گزينه‌ها بستگي به اين دارد كه چه كيفيت تصويري را انتخاب خواهيد كرد. تنها پس از زمان كوتاهي، اين نرم‌افزار شما را قدم به قدم در پيكربندي پيش خواهد برد. در اولين ديالوگ‌ها، زبان و دگمه‌ها را مشخص مي‌سازيد مي‌توانيد تنظيمات اين قسمت را به حال خود نيز واگذاريد. سپس توسط گزينه Start Clonezilla وارد برنامه اصلي خواهيد شد. به عنوان ماژول گزينه device-image disk/partition to/from image و به عنوان image-directory، گزينه Local-dev و سپس هارد USB كه توسط فضاي موجود در آن، آن را مي‌توانيد شناسايي كنيد، برگزينيد. هم اكنون Clonezilla، حافظه خارجي را اضافه مي‌كند تا بتواند به آن دسترسي داشته باشد. سوال مربوط را با [y] براي Yes پاسخ دهيد: توجه داشته باشيد كه به علت وجود زبان انگليسي گاهي اوقات حروف [Y] و [Z] جايشان عوض شده است. هارد USB : داراي قيمتي ارزان همه چيز به يكباره: در ديالوگ بعدي گزينه Savedisk را انتخاب كنيد، تا تماي هارد را به علاوه پارتيش‌هايش ايمن و ذخيره كنيد. عمل تاييد را با [Enter] انجام داده و سپس تصميم خود را براي اولين امكان يعني امكان زير بگيريد: Priority:ntfsclone>parttimage>dd اگر خواستار clone كردن سيستم و يندوز هستيد، اين گزينه بهترين انتخاب است. تنظيم بعدي را مي توانيد بدون تغيير، تاييد و قبول كنيد و سپس روش براي فشرده سازي را برگزينيد. اگر خيلي عجله داريد و درهارد USB خود نيز جاي زيادي را دارا مي‌باشيد. بهتر است گزينه آخر كه بدون فشرده سازي مي‌باشد را انتخاب كنيد. در اين ميان متد bzip2 كندترين ولي در عوض صرفه‌جوترين از لحاظ اشغال فضا مي‌باشد. هم اكنون تنها يك اسم براي Image بايد انتخاب شود. البته مشخص سازي اينكه كدام هارد را ميخواهيد Clone كنيد نيز بسيار مهم مي‌باشد. اگر تنها يك هارد در كامپيوتر شما وجود داشته باشد، Clonezilla نيز تنها آن را نشان مي‌دهد. اكنون كافي است كه چند بار با [Enter] و [Y] كار را تاييد كنيدف سپس ابزار clone عمليات را آغاز مي‌كند. بازسازي: فعالسازي هارد جديد Image درست شده است و داده‌ها نيزدر آن قرار دارند. اكنون بايد هارد زاپاس را زندگي بخشيد. براي اين كار بخش ايمن شده را درهارد جديد از حالت فشرده خارج كنيد. آمادگي هارد قديمي را بيرون بياوريد و دقيقا در همانجا هارد جديد را قرار دهيد. اين امر باعث نبود مشكلات اضافي در حين روشن شدن كامپيوتر مي شود.
اما اگر از پورت IDE مي‌خواهيد تبديلي را به پورت SATA داشته باشيد، بايد به احتمال زياد در بايوس ترتيب بوت را تغيير دهيد و به كامپيوتر بگوييد كه بايد از هارد SATA شروع كند. به جز اين مسئله مشكل ديگري در حين تعويض و تبديل پيش نخواهد آمد. باز كردن بسته Image اكنون دوباره Clonezilla را از سي‌دي فعال كنيد. دوباره ماژول device-image disk/partitionto/from image و به عنوان دايركتوري image local –dev را برگزينيد. اكنون آخرين زمان براي وصل كردن هارد خارجي با Image توسط USB مي‌باشد . همانگونه كه در بالا توضيح داديم بدينوسيله مي‌توان آن را به سيستم فايلي اضافه كرد. در قدم بعد گزينه resoredisk را برگزينيد و گزينه Reinstall grub in client HD MBR را توسط دگمه Space غيرفعال كنيد.
اگر اين كار را انجام ندهيد، Clonezilla، Linux Bootmanager Grub را در هارد جدي نصب مي‌كند. اما از آنجا كه در صورت استفاده از تنها يك سيستم عامل، از همان قبلي استفاده كرده و يا اصلا ديگر احتياجي به آن نداريد، اين مسئله تنها مزاحمت ايجاد خواهد كرد. در ديالوگ‌هاي پاياني، گزينه use the partition table from source disk و همچنين Image مربوط به هارد USB را انتخاب كرده و مشخص كنيد كه اين Image در كدام درايو بايد از حالت فشرده خارج شود. سپس Clonezilla آمادگي بازسازي داده‌هاي شما را خواهد داشت. تنها كافي است كه عمليات را سه بار تاييد كنيد چرا كه كليه محتواي هارد جديد پاك خواهد شد.
از قديمي به جديد: Clone كردن بدون مسيرهاي اضافي اگر هارد جديد را در درون دستگاه تعبيه و نصب كرده‌ايد، مي‌توانيد بدون انجام مرحله مياني توسط Image عمل Clone را انجام دهيد. Clonezilla در اين صورت فايل‌ها و تنظيمات را مستقيما به مقصد يا همان هدف مي‌برد.
مشخص سازي مبدا و مقصد براي استفاده از مسير مستقيم در ديالوگ مربوط به جاي گزينه Device –image disk/partition to/from image، گزينه device-device disk/partition to desk /partition را برگزينيد. در قدم بعدي به Clonezilla اعلام كنيد كه درايو مبدا و مقصد كداميك و كجا مي‌باشند اگر داراي دو هارد يكسان به علت اينكه هارد جديد كاملا همان مدل‌ هارد قديمي مي‌باشد، هستيد، تشخيص اين دو توسط حجم و يا شماره مدل ممكن نمي باشد. تنها مسائلي كه در اينجا كمك مي‌كنند شماره سريال يا Mount point مي‌باشند كه توسط آنها درايوهاي لينوكس به سيستم فايلي اضافه مي‌شوند.
در هاردهاي IDE هارد Master در اولين كنترلر IDE نام hda و هارد Slave‌در همان كنترلر نام hdb را به خود گرفته‌اند. به همين منوال نيز درايوها در كنترلر دوم نام‌هايhdc و hdd را به خود مي‌گيرند.
اما اگر بحث از هاردهاي SATA باشد، اينها بنا به اينكه به كدام پورت SATA وصل مي‌شوند به عنوان Mountpoint نام‌هاي sda و sdb و غيره را به همين صورت مي‌گيرند. بهتر است در صورت لزوم حتما كيس دستگاه را باز كرده و يكبار ديگر نگاه كنيد.
كپي دقيق تحت گزينه Clonezilla on-the-fly advanced extra parmetes دوباره با كمك space اولين عبارت را غيرفعال كنيد تا Bootmanager grub را نصب نكنيد. براي اينكه يك كپي دقيق 1:1 به دست بياوريد، بايد سپس در ديالوگ بعدي اولين گزينه را انتخاب كرده تا بدينوسيله جدول پارتيش‌ها را ذخيره كنيد. اين امر باعث مي شود تا بدانيد كه هارد قديمي چگونه پارتيشن بندي شده است.
پس از دادن آخرين اخطار بنا به اينكه تمامي داده‌هاي موجود در هارد جديد پاك مي‌شوند، Clonezilla كار خود را شروع مي‌كند. سپس بايد در بايوس ترتيب بوت را به هارد جديد تبديل كرده و مانند هميشه ويندوز را شروع كنيد.
