نرم افزار دستکاری در سورس برنامه ها
خدمت آقای جورسرائی ، پسوردی که برای اکستراکت فایلتان گذاشته اید کار نمی کند لطفاً پسورد معتبر را مرقوم فرمائید .
دوست گرامی من امتحان کردم و حتی برای اینکه جوابم با دلیل باشه فایل را خودم دوباره دانلود کردم و موقع پسورد نوشتن
JAVAD-JOURSARAEI
را قرار دادم و فایل باز شد شاید شما کپس لوکتان خاموشه یا بعد از نوشتن متن اسپیس قرار می دهید که فایل باز نمیشه
با تشکر از توجه شما
1390/1/18 1:4 بامداد
Service Manual
D e b u g g e R
13,691
176,890
iRanTK.iR
Heaven Tools Pe Explorer 1.99 R6 + New Patch + Keygen by Embrace
PE Explorer can handle a variety of different PE file types: EXE, DLL, SYS, MSSTYLES, CPL, OCX, BPL, DPL, SCR and more (including executable files that run on MS Windows CE platform).
PE Explorer gives you the power to look inside these PE binary files. PE Explorer contains a whole host of powerful analysis and editing tools for working with PE files. It comes with a PE Header Viewer, Section Editor, Exported/Imported API Function List Viewer, Syntax Lookup, Digital Signature Viewer, Resource Viewer/Editor, Dependency Scanner, and a Disassembler.
On top of all that, PE Explorer has one of the best UPX Unpackers built in. The open API allows custom plug-ins to be integrated.
PE Explorer: Features
Not only is our feature list impressive, PE Explorer has many different uses and substantially improves software quality and increase productivity for Windows developers.
GENERAL FEATURES
All details about the binary are collected without executing the file.
Automatically unpacks and decompresses files packed with UPX, NSPack or WinUpack.
You can work with damaged files (e.g. compressed files). If opening
a file produces an error, PE Explorer opens that file in Safe mode.
ADVANCED FEATURES
Visual Resource Viewer and Editor is one of the most convenient, safe and easy-to-use resource editors available for Windows.
Exported/Imported Function List Viewers provide you with the information on entry points, numbers, names, and calling syntax of exported and imported functions.
Quick Function Syntax Lookup displays the calling syntax for the found functions. [FAQ: How do I get parameters on function exports?]
Digital Signature Viewer lets you view a certificate-based digital signature of an executable file, validate the identity of the software publisher, and verify that the signature is valid and has been applied properly.
Peeks inside Delphi applications and edit the properties of controls on Delphi forms within the file.
Makes it easy to diagnose file problems, analyze, repair and restore the damaged section headers settings of PE files, examine PE file headers and correct checksums, repair damaged resources.
Application Manifest Wizard helps your legacy applications take advantage of the new common control styles and appearances featured in Windows XP and Vista, and mark them with a requested execution level on Vista.
POWER CODER TOOLS
PE Explorer Disassembler reconstructs the assembly language source code of target files. The output of strings found in the binary gives you a good knowledge of what some of the functions and subroutines called by this binary are.
Dependency Scanner helps you learn the minimum set of DLL files required for the EXE file to load and run.
Automatic unmangling of C++ external entity names and exported symbols back to human-readable names.
Strips the various types of information (Debug Information and Relocations) stored in the file.
TimeDate Stamp Adjuster modifies all the TimeDate Stamps to one uniform value.
With those features, you have plenty of reasons to want to include PE Explorer in your toolbox.
Minimum System Requirements
PE Explorer runs on all versions of Windows from 95 through Server 2003 and Vista
اين هم لينک هاي دانلود از دانلود سنترهاي ديگه :
اين هم لينک دانلود از سايت ، بدون پسورد :
