مطالبی در مورد PWM از دستورات برنامه نویسی PIC BASIC
jfrras
مدير انجمن تخصصی الکترونیک
3,100
74,089
48
سلام دوستان عزیز
این دستور کاربرد های فراوانی دارد: مثل کم و زیاد کردن نور ال ای دی های ثابت و کنترل دور موتور ها و غیره .
PWM یکی از دستور های برنامه نویسی PIC BASIC است .
[hide][/hide]
jfrras
3,100
74,089
48
این هم مطالب دیگر درباره همین موضوع:
PWM is a powerful and commonly used technique for controlling the analog circuits or power to inertial electrical devices and made practical by a processor’s digital output such as the modern electronic power switches.
1.0 Introduction
A digital device like a microcontroller can easily work with inputs and outputs. It has only two states, on and off. So you can use it to control a LED’s state such as on or off. In the same way, you can use it to control any electrical device on and off by using proper drivers such as transistor, relays, etc. But sometimes you need more than just “on​
