لیست آخرین تغییرات در آپدیت های پروگرامرهای TNM
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
همکاران گرامی دقت کنید برای دانلود آخرین نسخه می توانید از لینک زیر استفاده کنید :
کد:
[B][LEFT][INDENT][FONT="Tahoma"][SIZE="2"][COLOR="Navy"]
Version 7.17:(July 17 ,2010)
SST34HF1601,M50FLW080A,M50FLW080B,ATMEGA48PA  are added to Model2000+.
Version 7.16:(July 6 ,2010)
MX23LXX & MX25L256XX series are added to Model2000+.
Version 7.15:(June 25 ,2010)
56 Pin Flashes 29GL*** series are added to Model2000+.
PIC18F4XK20/PIC18F2XK20 Series are added to Model 2000+.
ATTINY13V is added to model 2000+ & ATTINY13 Bug in Model 1000+ removed.
New OBD Signature added.
Firmware Version is Upgraded to 10b (6/30/2010 11:27)
Version 7.14:(June 20 ,2010)
GAL20V8 UES Correction.
New XP/Vista Style GUI & Farsi Buttons.
Version 7.12:(June 10 ,2010)
EN29LV***  Vid is corrected to 11v
PIC18F2431,BR24E16 are added to model 2000+.
Socket2 Support.
Version 7.11:(May28 ,2010)
AT49LW040,AT49LW080 are added to model 2000+.
Version 7.10:(May23 ,2010)
LH28F160BJHE ,MX25L12805D,AT49LH00B4  are added to model 2000+.
Version 7.09:(May17 ,2010)
Firnware Update bug from version 7.08 is removed.
Version 7.08:(May13 ,2010)
Idle Status of ATXMEGA ISP pins set to low.
MX25L512 added to model 2000+.
Version 7.07:(May 6 ,2010)
Hex file without end of line is now supported.
AT91SAMX128,AT91SAMX256 are added to model 2000+.
New Farsi Help Pdf
Version 7.06:(April 24 ,2010)
All ATXmega Via PDI & JTAG are added to model 2000+.
PIC16F716 is added to 2000+.
Firmware Version is Upgraded to 10a.
Version 7.05:(April 17 ,2010)
Erase For AT24XX,AT25XX,93SXX series.
M29F400BB Auto Erase Before Program.
Farsi Menus for Windows Vista/Windows7.
New GUI: SVF Player button will be hidden until SVF file Load.
K9GAG08U0M Bug From Version 7.03 removed.
Version 7.04:(April 7 ,2010)
AT49LV1025,PIC16F737/PIC16F747/PIC16F767/PIC16F777 are added to model 2000+.
Firmware Version is Upgraded to 109.
Version 7.03:(April 3 ,2010)
ATXmegaA1 Family ,Via Jtag is added to Model 2000+.
AT91SAM7SXX Family (ARM7) ,Via Jtag is added to Model 2000+.
HY29F800ATT,TC58NVG4D1DTG00 are added to 2000+.
windrvr dll downgrade ability is added to all models.
Firmware Version is Upgraded to 108.
Version 7.02:(March 18 ,2010)
AT45DB161D Erase Protection Removed.
Version 7.01: (March 15 ,2010) P89C51RD2B, P89C51RD2H, MX23L3254,EN25S32T,W25X series
Version 7.00: (Feb 15 ,2010) Support for Windows7 32-bit & 64-bit.
Note: for ther first time in Windows 7 you must  Install ful software version7.00 from website.
AT49BV8192,STK11C48,AT25F1024/512, SA25F010L,SA25F020L,SA25F040L,SA25F080L,NAND01GW3B2,
W78E516B,W77E516 are added to model 2000+.
A29LV160AT is corrected.
Search Option is added to buffer Menu.
Version 6.91: (Jan 18 ,2010) ATMEGA165P is Added to 2000+.
PIC 16F636 is added to 100+,1000+.
Version 6.90: (Jan 18 ,2010) A290021 Voltage Modified.
Version 6.89: (Jan 16 ,2010) AT89LP6440 beta is added to Model2000+.
A29040B modified.
Version 6.88: (Dec20 ,2009) P8075GC,AT29C256 are added to Model2000+.
ATTINY13 Reset Disable Fuse is modified.
Firmware Version is Upgraded to 107.
Version 6.87: (Nov20 ,2009) MX25L1636D ,HY27US08121A, S99-50068 are added to Model2000+.
Version 6.86: (Nov13 ,2009) A41DC,MX25L8036D ,EN25F32 are added to Model2000+.
DSPIC33F hex file 0xff removal for faster programming.
Version 6.85: (Oct30 ,2009) MX25L2005,TH58NVG4D4,AT45DB041B(SOP8) are added to Model2000+.
Version 6.84: (Oct21 ,2009) AM29LV008 is added to Model2000+.
Version 6.83: (Oct20 ,2009) BR93CXX, MX28F2000,A29L004,A29L008,SM8952 are added to Model2000+.
Version 6.81: (Sep26 ,2009) S29JL032,ST93CSX6 ,LH28F800BVE are added to Model2000+.
Attiny13 ISP fuse Write Optimized.
Version 6.80: (Sep14 ,2009)  ES29LV800E voltage increased %10.
Attiny13 ISP fuse Write Error Removed.
Version 6.79: (Sep 5 ,2009)  29F08G08CA, FM25CL64,A51DCM,MBM29F800BA,AS29F200
AT90USB82/162  are added to Model2000+.
Erase Confirmation Box & Setup is Added to All Models.
Version 6.78: (August 24 ,2009)  49LV010/49LV040/49BV010/49BV040 are added to Model2000+.
ESMT F25L016A erase & program bug removed.
Version 6.77: (August 7 ,2009)  M95128/M95256 ,PCF85102-103,PCX8582 are added to Model2000+.
Hex file format with incorrect number of bytes is now supported.
Version 6.76: (August 3 ,2009)  MX29LV160DTT, MX29LV160DBT,PM25LV080,PM25LV016 are added to Model2000+.
E2P File Format is added.
Version 6.75: (25 JULY 2009)  A29L400A-S29190A-S29290A-S29390A-XL9020-XL9040-AK6420
-AK6440-AK6480 are added to Model2000+.
Version 6.74:( 8 JULY 2009) Beter AutoDetect for Atmega8
Version 6.73:( 3 JULY 2009) PIC12C672 added to Model 2000+
Version 6.72:(30 JUNE 2009) AT25HP256-512 Bug removed.
Buffer 2-3-4 byte Fill is added to all models.
Version 6.71:(25 JUNE 2009) AM29F016D,AM29F032D,MX29F016 are added to Model2000+.
Firmware Version is Upgraded to 105.
ATTINY25 Check Removed.
Version 6.70:(10 JUNE 2009) 95080 Auto Lock Removal.
Version 6.69:(7 JUNE 2009) HY27UBG8BU5MTR corrected.
PIC16F887/886/884/883/882 ,S-24S45, A278308A,A277308 , LST28002 are added to Model 2000+.
EN25T160 Autodetect is added to Model 2000+.
Version 6.68:(2 JUNE 2009) AT28C040,S29C5001,AT28C040,PT28C040,DSPIC30F4012,H27UAG8T2MTP are added to Model 2000+.
Version 6.67:(16 May 2009)  M27W101 verify voltage ,Hex file format corrected
Version 6.66:(12 May 2009)  HY27UBG8BU5MTR ,M27W101,TMS28F200AZ are added to Model 2000+.
SST25LF0XX/SST25VF040 Program Bug is removed.
Firmware Version is Upgraded to 104
Version 6.65:(2 May 2009)  AT45DB081D added to Model 2000+.
Pin38 HIZ for 93CXX & 35XX && 25XX
Firmware Version is Upgraded to 103
Version 6.64:(25 April 2009)  SM59264,AM49F001, A290021U ,AT26DF081A are added to Model 2000+
VCC of SST39VF040 is reduced for new MPF series.
Version 6.63:(19 April 2009) P89C51/52/54/58BP are added to Model 2000+.
Hex File Format Bug from Version 6.62 Removed.
Version 6.62:(16 April 2009) EN25F16/20/10/05 , SST25LF040A/20A, W27C02,SST25WF512-80 are added to Model 2000+.
A29040B VCC decreased %10.
K9KAG08U0M,K9GAG08U0M are added to Model 2000+.
Version 6.60:(4 April 2009) 12F6XX_16F6XX , S29AL016D70TFIO2 are added to Model 2000+.
M29W160ET VCC decreased %10.
49LF008A(FLASHRC40A) Id Exit Bug is fixed.
Version 6.59:(17 March 2009) AM29LV004TC/BC added to Model 2000+.
Version 6.58:(11 March 2009) A27f010 ,A29512 are added to Model 2000+.
SOP44 Validation.12F675 calibration verification removed.
Version 6.56:(25 Feb 2009) M28W800B/160B/320B/640B , PM25LV010/20/40 S25FL001/2/4/8/32/40/64 , M25PE10/20/40/80 ,EM25LV010 are added to Model 2000+.
AF93BXX,AF24BCXX Serial eeproms are added to model 2000+.
35080 increament reg write is added.
Version 6.55:(19 Feb 2009) DSPIC30F1010/2020/2030 are added to Model 2000+.
Version 6.54:(17 Feb 2009) AT49F020,AC39LV010,AC39LV020,SST25VF512 are added to Model 2000+.
Version 6.53:(10 Feb 2009) EN29LV640B,M29W640DB/DT/FB/FT/GL/GH/GT/GB are added to model 2000+.
Firmware Version is Upgraded to 102(tested for All 48 pin sst flashes)
Version 6.52:
MBM29PL32TM,mx26lv160btc are added to Model2000+.
Vresion6.50  Bug for 48 pin chips is removed.
Firmware Version is Upgraded to 101.
Version 6.50:( 3 Feb 2009) 28F008SA,ESMT25L008A are added to Model2000+.
Very Fast Configuration of All Xilinx FPGA is added to Model 2000+ by selecting  XILINX_FPGA
Firmware Version is Upgraded to 100.
Version 6.47:( 20 Jan 2009) M28F512,AT49BV/LV160_161,MX26LV800T are added to model 2000+.
Version 6.46:( 13 Jan 2009) PM49FL002T bug removed,PIC18FXXJXX Reset after Program is added.
AT29C1024 PLCC44 are added to Model 2000+.
Firmware Version is Upgraded to e7.
Version 6.45:( 10 Jan 2009) TMS28F512A,M29F010B,PIC18F45J10,PIC16F83,87,88
PIC18F2XJ_4XJ_6XJ_XX8_XJXX Series are added to Model2000+(80 Devices).
PIC18FXX bug from version 6.44 is removed.
Version 6.44:( 4 Jan 2009) MX25L8005 autodetect is corrected. HY29F800TG,U7462FB,U8102GB ,TC58128AFT,W27E512,ICSI89C52A
Program & Erase Speed of TSOP48 & SOIC8 Flashes & AT45DB*** TSOP28 ics are increased x2 times.
Firmware Version is Upgraded to e6.
Version 6.42:( 18 Dec 2008) XLS2804A,AT26DF321,MX29LV008BBTC,MX29LV008BTTC,A290011TL,W77E58,A25L040,A25L080,A25L020,A25L010
,A25L016,A25L032 , MX29LV040,KH29LV040 , W77E58,W77LE58 ,M45PE10,M45PE20,M45PE40,M45PE80,M45PE16are added to Model 2000+.
A27020 voltage is corrected.
ISP  PIN3 (RESET) is mapped to MCLR for 18F97J60.
Version 6.41:( 4 Dec 2008) S-29255A,S-29355A,S-29L130A,S-29L220A,S-29L330A,BR9010/9020/9040F,PIC18F97J60,S29A016D,F49L800BA/UA are added to Model 2000+.
ERASE user ask box in farsi  is added to all models.
Firmware Version is Upgraded to e5.
Version 6.40:( 30 Nov 2008) PCF85116,W39V040FA,W39V040FC,PM49Fl004T,MT28F002C5,A25L80,A25L16 are added to Model 2000+.
Version 6.39:( 16 Nov 2008) L29004CP,EN25T80,KM93C06,KM93C06/07/57/67,ISSI24C01-16,SST49LF020/A,
SST49LF008A(TSOP40),SST49LF004B(TSOP40) are added to Model 2000+.
27C0XX EPROM Programming Speed Increased 8 times.
EEP binary format support added to the all models.
Firmware Version is Upgraded to e4.
Version 6.38:( 12 Nov 2008) M48T129,M48Z128,SM8951BC,KH29LV400CT/B are added to Model 2000+.
A2940B VCC is lowered %10. Amic A29L800A temporary unprotect removed(low Voltage programming).
ATMEGA329/3290/649/6490 are Added to All Models.
Version 6.37:( 7 Nov 2008) AT25F512,EM25LV512,SST39VF320,W29EE512,FM18L08,ATTINY24(PARALLEL) are added to Model 2000+.
Firmware Version is Upgraded to e3.
Version 6.36:( 4 Nov 2008) F29C51004T,M29W320ET, 25512 are added to Model 2000+.
Version 6.35:( 29 Oct 2008) M45PE20(beta) is added to Model 2000+.
Version 6.34:( 25 Oct 2008) HY27UV08BG5M,A29L800AUV  are added to Model 2000+.
M29W160DT voltage is corrected.
Version 6.33:( 16 Oct 2008) W39V080AP,AM29DL163,MX29LV320AB are added to Model 2000+.
Version 6.32:( 11 Oct 2008) W27E040, E28F200CVare added to Model 2000+.
Version 6.31:( 26 Sep 2008) X25170,AC39LV080,AT93C46R ,MX29LV800BT,W27c010 are added to Model 2000+.
Version 6.30:(22 Sep 2008) 12C508-509 2 last byte error removed.S25FL016A is added to Model 2000+.
Version 6.29:(13 Sep 2008) EN25F80,MX27C2001,W39V040BPZ are added to Model 2000+.
Version 6.28:(8 Sep 2008) FM24C04 ,W25X16,W25X32,W25X64 are added to Model 2000+.
Version 6.27:(6 Sep 2008) AC39LV040 is added to Model 2000+.
Version 6.26:(2 Sep 2008) M50FW040(TSOP40) is added to Model 2000+.
Version 6.25:( 31 August 2008) S29GL064M90TFI-R7,FM93C86,EN29LV160AT,MBM29LV016T are added to Model 2000+.
Version 6.24:( 26 August 2008) AT49F4096A,ES29LV800EB,LH28F800BJ,EN29LV800BB are added to Model 2000+.
Version 6.23:( 24 August 2008) HN27C1024 bug removed, XC95***L erase timing is modified.
Version 6.22:( 12 August 2008) K9LBG08U0M is added to Model2000+. 74HC22106 is added to tester.
Version 6.21:( 1 August 2008) E28F800B5B, TH58NVG3D4BTG00,HY27UH088G2M  are added to Model2000+.
AT49BV163DT bug is Fixed.
ATTINY24/44/84(ISP) are added to all models.
Version 6.20:( 24 July 2008) 74595 tester bug is removed,KM93C46,KM93C56,KM93C66 are added to Model2000+.
Version 6.19:(13 July 2008) MBM29LV004T/B, F25L004 are added to model 2000+.
Version 6.18:(4 July 2008) PIC16C505, MX25L1605A, NEC4664 , AT49BV322A are added to model 2000+.
Version 6.17:(18 Jun 2008) P87C52/P87C51,87C64,M29F800DB,HY27UF08121A are added to model 2000+.
27UF081G2M Autodetect is added.
Version 6.16:(1 Jun 2008) MBM29LV650UE ,AM29LV081B are added to Model 2000+.
CPLD Programming & Verify Speed is Increased 4x in Model 2000+.
Firmware Version is Upgraded to e2.
Version 6.15:(29 May2008) EN29LV641H/L,EN29LV320 Bug is removed.
Version 6.14:(28 May2008) EN29LV641H/L, SST39VF6401B,SST39VF6402B,SST36VF1602C/E,SST36VF1601E,SST25VF080B
Philips P89C51X2,P89C52X2,P89C54X2,P89C58X2 are added to model 2000+.
PIC16F57(ISP) Bug for model 100+/1000+ is Fixed.
Version 6.13:Farsi Support For None UNICODE windows98 .
Version 6.12:(24 May2008) Farsi Support For UNICODE windows .
EN29LV640H,TC58FVM5B2A,TC58FVM5B3A,TC58FVM5T2A,TC58FVM5T3A are added to 2000+.
Version 6.11:(20 May2008) A29L040 ,A27020 are added to Model2000+.
PIC16F57 code size is corrected.
M28W800C autodetect is added to model 2000+.
Version 6.10:(12 May2008) 93SXX protectionbug  removed.
Version 6.04:(12 May2008) Farsi Support for some windows version.
AT25XX auto write protect remover before program.
SST36VF1601C is added to Model 2000+.
Version 6.02:(10 May2008) 93SXX protection removed.DSPIC30F5011,DSPIC30F5013
M29W320DB/DT are added to  to Model2000+.
Version 6.01:(4 May2008) M50FW080,S29GL064,SST39VF088 are added to Model2000+.
Firmware Version is Upgraded to e1.
Version 6.00:(2 May2008) Farsi Help for all models.
39VF3201 AutoDetect is added to model2000+.HY27UF088G2M is added to model 2000+.
Version 5.33: (24 April 2008) EN29F40,49LF080A are added to model 2000+.
Version 5.32: (17 April 2008)  LH28F320BVHE,DSPIC30F6014 are added to model 2000+.
Version 5.31: (9 April 2008) Pm39LV512,Pm39LV010,Pm39LV020,Pm39LV040, A29L160UV,A29L160TV
DSPIC33FJ256GP710 , M29F040B Auto detect,K9HBG08U1M are Added to model 2000+.
Version 5.30: (10 March 2008) W39L040AP,A29040B,EN29LV040B,SST36VF1601,EN29LV320 are added to model 2000+.
Version 5.28: (30Feb 2008) M29F800AB,PA28F800BVB, E28F008S5,AM29F400AB,AM29F800BB
MBM29F400TA,LH28F008SCN  added to model 2000+.
Firmware Version is upgraded to e0.
Version 5.27: (18 Feb 2008) A290021UL is added to model 2000+.A290021TL ID Bug is removed. None PES GAL pulse time is added to model 2000+.
Version 5.26: (18 Feb 2008) A290021TL,W39V080FA,MX29LV160CTTC,HY27UU08AG5M,TC58V64BFT are added to model 2000+.
Version 5.24: (13 Feb 2008) DSPIC30F2011 bug is removed in some 2000+
Firmware Version is upgraded to df.
Version 5.23: (12 Feb 2008)AT49BV163DT,MK48T08B,M48Z35Y,M48Z30Y are added to model 2000+
Firmware Version is upgraded to de.
Version 5.22:(7 Feb 2008)  W78E58B,HY27US08561,CAT28C512, M50FW002, DSPIC30F2011  are added to model 2000+.
DSPIC supply pin increased.
Firmware Version is upgraded to dd.
Version 5.20:(31 Jan  2008)  29DL164,29F160,25LCXX,NM25CXX  are added to model 2000+.
Version 5.19:(28 Jan  2008)  TE28F800CBV,EN25P0XX,S29AL004D  are added to model 2000+.
Version 5.18:(16 Jan  2008) HY27UT088G2M,AT45DB321(TSOP32)  are added to model 2000+.
Version 5.17:(12 Jan  2008) S29AL008,HY27UU088G5M,AT26DF161 ,AT45DB161D are added to model 2000+.
Version 5.16:(5 Jan  2008) IS25C256,IS25C128 , F29C51002T , M29F002B are added to model 2000+.
Version 5.15:(30 Dec 2007) HN58C256A is Added to Model 2000+, Auto Detect Bug for 49LF030A is removed.
DSPIC 30F2010 is added to the device list.
ATmega64 - ATmega128- ATmega640 - ATmega1280 - ATmega2560  Program & Verify Speed Increased %500. ( Select (FAST-ISP))
Firmware Version is upgraded to dc.
Version 5.14:(24 Dec 2007) EN29F040,K9F6408U0C 44 pin are added to model2000+.
Firmware Version is upgraded to db.
Version 5.13:(17 Dec 2007) HY27US08121 is added to model 2000+.W25X80,W25X40,W25X20,W25X10,
 M25P16, M25P05, M25P10, M25P20, M25P32, MX25L4005, SST49LF003B, SST49LF030A are added to model2000+.
Firmware Version is upgraded to da.
Version 5.12:(12 Dec 2007) nand Autodetect bug for some 2000+ series is removed.HY27UT084G2M is added to model 2000+.
Firmware Version is upgraded to d9.
Version 5.11:(10 Dec 2007) AT45DB081B TSOP28 is added to model 2000+. Search & save fuse bit bug is removed.93CXX rotated pin support is added.
Version 5.10:(2 Dec 2007) AT45DB041B TSOP28 is added to model 2000+.
Version 5.09:(1 Dec 2007) SDA2526,SDA2546 are added to Model 1000+ & 2000+.
Version 5.08:(8 Nov 2007) M29W16D erase bug for some IC revisions removed.
Firmware Version is upgraded to d8.
Version 5.07:(6 Nov 2007) Detect Algorithm Bug for XXF002X flash series is removed.
MX29F004/FM24CXX/AT49BV002A(N)/AT49LV002A(N) ,MX25L8005 ,AT25640 are added to Model 2000+.
Version 5.06:(28 Oct 2007):MX29F040-MX29F100T/B-AM29F100T/B are added to model2000+.
Version 5.05:(19 Oct 2007):30F6014A erase & read bug removed.
Firmware Version is upgraded to d7.
Version 5.04:(1 Oct 2007):89C51RD2/RC2/ED2/RB2 Parallel programming is added to Model2000+, Program & Verfiy Speed of AT89CRX2 is increased %400.
A49FL040TL-EN29LV160AB/T -TC58NVG2D4CTG00 are added to model 2000+.
ATTINY25/45/85 are added to all models.
Firmware Version is upgraded to d6.
Version 5.03:(22 Sep 2007):AT49F512-HY27UH084G2M-MX29LV008CBTC(TSOP40)-SST39VF1681-SST39VF1682-AT49F8192A,K9LAG08U0M
are added to Model2000+. dsPIC30F4011 on ZIF programming bug is removed.
New 2000+, VCC/VPP generation table is added.
Firmware Version is upgraded to d5.
Version 5.02:(9 Sep 2007):MBM2212 is added to 2000+
Version 5.01:(8 Sep 2007): SST39VF08 (TSOP40),E28F004(TSOP40),MX29LV008(TSOP40),MX26LV008(TSOP40),MX29LV004,MT28F004(TSOP40)
A29040 - AT90CAN32(ISP)- AT90CAN64(ISP)- AT90CAN128(ISP) are added to model2000+.
Firmware Version is upgraded to d4.
Version 5.00:(1 Sep 2007): Supports for Windows Vista for All Models.
AT89S51,AT89S52,AT89C55WD Program Speed is Increased %300 in Model 2000+.
M28W160CT,M28W160BT,MBM29LV160TE,MBM29LV160BE,TC58FVT160A,TC58FVB160A,MX29LV800CB,MX29LV800CT,
A29L800T,A29L800B,AT49LV1614A,AT49LV1614AT,AT49BV1614A,AT49BV1614AT,AT49LV1604A,AT49LV1604AT,AT49BV1604A,
AT49BV1604AT,M29W400BB,M29W400BT,SST29EE512,AT45DB161B(TSOP28),K9F6408U0C(TSOP48) are added to Model2000+.
HY27UU088G5/HY27UG088G5 bug removed.
Firmware Version is upgraded to d3.
Version 4.91:(18Agust 2007): AT29LV010-40 ,PM39F010-40 ,LH28F160BVHE are added to Model 2000+.
Version 4.90:(11Agust 2007): AT29C040 TSOP32 Programming on TNM TSOP48 adaptor,
Graphical Information for IC Insertion.
29F8G08FAB ,K9L8G08U0A are added to model 2000+.
Version 4.89:(3 Agust 2007): ATmega169 Erase Bug is Removed. 895X tester is added to all models.
Version 4.88:(31 JULY 2007): 16F57(ISP) is added to device list.
Version 4.87:(29 JULY 2007): K9F4008W0A is added to Model2000+.
Version 4.86:(28 JULY 2007): SST28SF040A,K9W8G08U1M,K9WAG08U1M ,AT45DB161B are added to Model2000+.
Identical ID Selection Window is added to all models.
SRAM Tester Error Fixed.
Version 4.85:(20 JULY 2007): AM29LV040B is added to Model2000+,Nand Flash Verify Error Retry Mode is added.
K9G4G08U0A is added to Model2000+.
EPROM 128K-512K 32 pin Verify Speed is Increased %400.
Version 4.84:(17 JULY 2007): PIC16F72 is added to all models.
Version 4.83:(15 JULY 2007): Nand Programming Wait for Busy. AT89S51 ISP Bug  in Model 1000+ removed.
Version 4.81:(14 JULY 2007): Nand Flash 0xff Skip During programming.New FW for Nand USB feedBack.
Version 4.80:(8 JULY 2007):Speed Upgrade in 2000+.
AT89C5X & Eprom 2764,27128,27256,27512,2780 Read & Verify Speed is Increased %400.
Nor Flash Read & verify Speed is Increased %100.
Nor Flash Program Speed is Increased %20.
Nand Flash Program& Verify  Speed is Increased %50.
AT45DB11,AT45DB22,AT45DB44 are added to Model 2000+.
Version 4.75:(26 JUN 2007) S29AL016M,MX29F400C are added to Model 2000+.
Version 4.74: (15 JUN 2007) Nand Flashes up to 2 Gig  are added to device list.PIC18F8722 Family read Fuse error is Fixed.
Version 4.73: 89S51-2 'Unkown Device' Bug in model 1000+ is removed.
Version 4.72:(20 May 2007) 93S56 bug in 2000+ is removed.
Version 4.71:(16 May 2007) 39VF040 bug in some systems is removed. (Hardware Signature CA)
Version 4.70:(15 May 2007)
NAND Flash Memoris are Added to Model2000+.
M95320,M95640 Family are added to Model 1000+,2000+.
New memory Allocation Shceme for Up to 1 Gigabytes Files is added to all Models.
Some New Series of W39V040 chips are added to Model 2000+.
AM29F400BB,AM29F400BT ar added to Model2000+.
HOLTEK HT93LC46A/HT93LC46B/HT93LC56A/HT93LC56B/HT93LC66A/HT93LC66B Serial EEproms are added to Model 1000+/2000+.
Version 4.61:(8 APRIL 2007)  M29F200BB,M29F200BT,M29W800CB,M29W800CT,M29W800DB,M29W800DT are added to Model 2000+.
Version 4.60:(16MARCH 2007)  AM29F200BB,AM29F200BT,M29F400BB,M29F400BT are added to Model 2000+.
Version 4.59:(15MARCH 2007)  PIC16C745 fuse bit is corrected ,AutoDetect for PIC18F8722 Family.
Version 4.58:(14MARCH 2007)  SST25VF040B is added to Model 2000+.
Version 4.57:(12MARCH 2007)  PIC18F8722 family are added to all models , SM8958A is added to Model 2000+.
Version 4.56:(5MARCH 2007)  SST39VF020,SST39VF010,SST39VF512,SST39LF020,SST39LF010,SST39LF512,24LC00 are added to Model 2000+.
Version 4.55:(25FEB 2007)  None Standard hex file format with bad checksum is also supported.
Version 4.54:(18FEB 2007)  A notification sound for reload file checksum change.
Version 4.53:(13FEB 2007)  NEC UPD75P108B ,SST49LF040B,SST49LF040,W39V040FC,W39VF040CP are added to Model 2000+.
Version 4.52:(4FEB 2007)  SST39VF040 & HY29F040AC are added to Model 2000+.
Version 4.51:(24JAN 2007)  DSPIC 4013 ID is Corrected in Model 2000+.
Version 4.50:(12JAN 2007)  ATtiny26L RSTDSBL fuse clear algorithm is added to Model 2000+.
Version 4.49:(7JAN 2007)  PIC16F684,PIC16F688  are added to Model 2000+.
Version 4.48:(30DEC 2006) W27C020P is added to Model 2000+.
Version 4.47:(26DEC 2006) 16f877 programming Bug is fixed in Model 1000+. ATmega169 is added to all model device list.
Version 4.46:(18DEC 2006) Vcc +- %5 tolerance is added in Model 2000+.
Version 4.45:(17DEC 2006) PIC16F872 Programming Bug is Fixed in Model 2000+.
Version 4.44:(6DEC 2006) M29F040 Flash is added to Model 2000+.
Version 4.43:(2DEC 2006) 4518 bug in tester is removed, X2444 & AT29C256 PLCC32 are added to Model 2000+.
Version 4.42:(24NOV 2006) 89S5X ISP Programming Speed is increased in Model 2000+, Auto Detect for most PLCC32 Flash is added.
Version 4.41:(16NOV 2006) Auto increment Serial number is added to the buffer menu.
Version 4.40:(7NOV 2006)PIC16F628A fuse reading from hex file bug is removed, AT49LH002,AT49LH004 are added to the Model 2000.
Version 4.39:A bug with ATmega2560,2561 for program size over 128k is fixed.
Version 4.38: STK10C48,STK10C68,STK20C04,X2212,X2212I are added to the device list.
Version 4.37: DS1220,DS1225,DS1245,M48Z02,M48Z18,M48T58 are added to the device list.
Version 4.36: 49SLF003A bug is fixed.
Version 4.35: 39SF010A,39SF040   are added to the device list.
Version 4.34: 27SF010,27SF256,27SF512,M28W800CT,M28W800CB,  are added to the device list.
Version 4.33: W27C020  is added to the device list.
Version 4.32: SST39F010A, Hardware Version is added  to windows caption.
Version 4.31: PIC16F91X are added to the device list. 3f->ff conversion in some pic hex file.
Version 4.30: New User Interface, 2708 Eprom & DS1230 NVRAM are added to the device list.
Version 4.20: TMS2516,TMS2532,TE28F800B5B  are added to device list, 93S56 data is swaped.
Version 4.19: TMS2564 is added to the device list.
Version 4.18: New CMOS/TTL ICs are added to the Tester
Version 4.16: ATMEGA2560/2561/1280/1281/640 are added to the device list
Version 4.15: An easier way for load 'All Files' & save as is added in this version
Version 4.14: PIC16F877A programming bug is removed in model2000+.
Version 4.13:AT89S8252(ISP),AT89S8253,AT89S8253(ISP) are added to model2000 Device list, Win98 Install problem fow WD8.01 is solved.
Version 4.1: UV Eprom Programming Speed is Increased 5-8 times.
Version 4.06:EEPROM File Format (*.EEP) is added to load file,Some TSOP48 FlashMemories are added to the device list.
Version 4.05:USB Driver (Windriver) is upgraded from version 6.02 to version 8.01.
Version 4.04:PIC16f84,4099,74165 are added to the device list.
Version 4.01:New system for fusebit display, First Software version with the supports of MUP2000 Hardware with 2100 Device Support
Version 3.7: EPM7128 bug removed
Version 3.6: JAM version 2 support,  93s46-66
Version 3.5: PIC16F62XA,PIC18F24XX,PIC18F25XX,PIC18F26XX,PIC18F44XX,PIC18F45XX,PIC18F46XX,
AT89C51AC2 , Altera CPLD MAX7000,MAX7000A  and any other Altera Devices by JAM  file are added to the device list.
Version 3.3: PIC12CXX,PIC16CXX ON ZIF Programming is Added to Model1000+,  (1367 Device For Model1000+ , 451 Devices For Model100+)
Version 3.2: USB Voltage Check & Max Current Check For Model100C+ and Uppers
Version 3.1: ISP Delay for Version100B+ and Uppers.
Version 3.0: First version with support of model 1000+ , Many new Devices is Added to model 100+
Version 2.2: Fuselist Load & Save Option is Added to FuseList dialogue Box.PIC16F870/871/872/873/874/876/877 are added to the  list.
PIC16F876A EEPROM Verify Verify bug is Fixed.
Version 2.12: A Bug with IC Tester for 24 pin and larger ICs is Fixed.
Version 2.11: A Bug with xilinx Environment variable is Fixed.
Version 2.1: PIC16F876A Fuse Write & EEPROM Verify BUG is Fixed.
Swap Buffer Byte option is added to buffer Menu.
Version 2.0: EEPROM/FLASH SECTOR WRITE /READ is added (Buffer/Properties).
Version 1.8: PIC12C5X USER ID READ-WRITE are added to the fuse list
Version 1.7: 89C51RC - 89C51RX2 - 89S/LS8252 - 89LS/S53 - ATTINY13  is added to the Device List
Version 1.5: Serial EEPROMs are added to the Device List (24cXX,93CXX)
Version 1.4: 89C55WD Device ID Detection Error On some systems Fixed.
Version 1.2: First Release with 150 Devices
Hardware:
Model2000+ : Basic 2000+  Model
Model1000+ : Basic 1000+  Model
Model100C+: USB Voltage & Maximum Current Measuremnt support.
Model100B+: ISP Delay setting support.
Model100A+: 89C51RD2 & other UART based mcu programming support.
Model100+: BASIC 100+ Model
[/COLOR][/SIZE][/FONT][/INDENT][/LEFT][/B]
http://www.tnmelectronics.com/Downloads.html
http://www.tnmelectronics.com/Upgrade.html
پس از آپلود آپدیت ها در سایت خودداری کنید .
لیست تغییرات در نسخه 7.18
کد:
[B][LEFT][FONT="Tahoma"][SIZE="2"][COLOR="Navy"][INDENT]
Version 7.18:(July 17 ,2010)
MX25L6445,ATMEGA328 are added to Model2000+.
AT45DB041B/81B & ATMEGA48PA BUG is CORRECTED.[/INDENT][/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
لیست تغییرات در نسخه 7.19
کد:
Version 7.19:(Agust 13 ,2010)
Lockbit Verify for Atmega16/32/64/128/2560/8/48/88/168/13/25/45/85 series.
STK16C88 are added to Model2000+.[/INDENT][/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
ليست تغييرات در نسخه 7.20
کد:
[B][LEFT][INDENT][SIZE="2"][FONT="Tahoma"]
Version 7.20:(Agust 5 ,2010)
S99AL016DBT1,FM31256 , S29AL016J ,M95P08 are added to Model2000+.
ESMT F25L004/008A Erase Bug is Removed.
ATMEGA88 Debug Wire Fuse Omited.[/FONT][/SIZE][/INDENT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
ليست تغييرات در نسخه 7.21
کد:
Version 7.21: (Sep 14 ,2010)
A29040B Program Timeout Error is corrected.
S29GL128P10TFI-O1 , AT25F2048 , EN29LV800CB are added to model 2000+.
56 Pin AutoDetect & id digit 3 is changed . new timing for 56 Pins.
Firmware Version is Upgraded to 10c (9/14/2010 5:01) CHKsum:D1FA[/INDENT][/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
ليست تغييرات در نسخه 7.23
کد:
Version 7.23: (Sep 14 ,2010)
AutoDetect for All 40 Pin TSOP Flashes are available.
JS28F128J3(TSOP56),ATMEGA164P/324P/644P are added to Model2000+.
A29L008ATV VCC from 80 to 100
AutoDetectBug for ATmega128 in Model1000+ is removed.
Firmware Version is Upgraded to 10d (10/7/2010 3:16) CHKsum:E94D[/INDENT][/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
ليست تغييرات در نسخه 7.24 و 7.25
کد:
[B][LEFT][FONT="Tahoma"][SIZE="2"][COLOR="Navy"][LEFT][INDENT]
Version 7.25: (Oct 16 ,2010)
M29DW323 added to model 2000+.
Version 7.24: (Oct 10 ,2010)
PT28C020 Program Bug Removed.[/INDENT][/LEFT][/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
ليست تغييرات در نسخه 7.26 و 7.27 و 7.28
کد:
[B][LEFT][FONT="Tahoma"][SIZE="2"][COLOR="#000080"]
Version 7.28: (Oct 27 ,2010)
JS28F640 56 pin,M29W008, S29GL064A90TFIR7 are added to model 2000+.
Version 7.27: (Oct 22 ,2010)
JS28F320,LH28F160S5 56 pin are added to model 2000+.
Version 7.26: (Oct 19 ,2010)
18F4550 new version.
S29GL064M90TCIR4-S29GL064N90TFIO4 are added to Model 2000+.[/COLOR][/SIZE][/FONT][/LEFT][/B]
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
Service Manual
D e b u g g e R
13,697
176,898
iRanTK.iR
کد:
[B][LEFT][FONT="Tahoma"][SIZE="2"][COLOR="#000080"][INDENT]Version 7.33: (Nov 29 ,2010)
W25P16/32/64/80 ,SST29VF020/040 ,S29530A/630A ,S-24CS01-08Aare added to Moedl2000+.
Version 7.32: (Nov 15 ,2010)
PA28F400BXB Erase Corrected.[/INDENT][/COLOR][/SIZE][/FONT][/LEFT][/B]
لیست تغییرات در نسخه 7.32 و 7.33
