جهت قفل کردن نرم افزارهای گوشی - AppLocker v1.0.0
6,774
29,828
جهت قفل کردن نرم افزارهای گوشی - AppLocker v1.0.0 s60v3_v5 Unsigned ENG Translated Full
دوستان توسط این نرم افزار می توانید برای رود به نرم افزارهای نصب شده بر روی گوشی رمز گذاری کنید
The program poses a password as access to your smartphone as a whole, and to programs / applications / processes separately!
When you first start the program prompts you to select a single password, confirm it, select a secret question ...
Then you get to the main menu of the program to work with locks.
At any time you can change the password (passed sootv.punkty query program), but to return to the menu when the program starts, it is enough to clean the body, for example, the program G-Force etc.
