امولاتور دستگاه بازی GameBoy + چند بازی
6,787
29,884
vBagx.v1.25_Full Nseries
vBag is a GameBoy Advance emulator that can
play GBA games on your mobile phone.
vBagX is the latest version of vBag.
Features
- For S60v3 and some S60v2, full speed with
perfect sound effects for most games
- Big rom size support (full support for 32M
rom)
- Each rom with 5 save/load slots
- Speed adjustment option and frameskip
option
- Graphics mode option
(origin,full,landscape,landscape origin)
- Save/Load in games (flash,eeprom,sram up to 128K)
- Key map setting
- Sound volume switch
- Thread priority option
- Two Graph Output Mode: bitmap mode
(default),direct mode(speed improved, but
some phones not supported)
1)Unpack
2)install :C or :E
3)(X-plore) Put GBA file TO :)C or :E Data/Other/Vbagx)
4)Run Vbagx App ,you can see and play the Game
#VBAGX no need register already Full
همانطور که در توضیحات انگلیسی میبینید باید ابتدا برنامه رو نصب کنید سپس توسط یک فایل منیجر بازی را با فرمت GBA به درایو C یا E (بستگی به محل نصب) در آدرس
Data/Other/VbagX
منتقل کنید و سپس وارد برنامه شده و بازی کنید
6,787
29,884
R-Type III - The Third Lightning Game Boy Advance
Dark Empire Bydo seeks to destroy our race.After their failure in two campaigns Bydo Empire begins categorical attack.You - the last pilot on Earth; you must manage the untested R-90 against the Bydo.Do your way through the amazing levels filled with hordes of enemy inhabitants and insanely huge bosses!
1)Unpack
2)install :C or :E
3)(X-plore) Copy GBA file TO :)C or :E Data/Other/Vbagx)
4)Run Vbagx App ,Just Start and play the Game​
6,787
29,884
Operation Armored Liberty Game Boy Advance
Tank shooter, reminiscent of the game Super Battletank for SEGA Mega Drive / Genesis.The action takes place in Iraq, you are fighting with tanks, helicopters, go from missile attacks.Experienced player in this old game fun enough for 1,5-2 hours maximum.
1)Unpack
2)install :C or :E
#VBAGX no need register already Cr@ck
6,787
29,884
AirForce Delta Storm Game Boy Advance
Unlike traditional two-dimensional shooters 2D, this flight simulator is much deeper.Players can change the height of the flight of his plane during an air battle in the style of action and thus to attack the enemies at different heights, gaining a fair advantage.You can carry out bomb attacks on ground targets, almost a vertical height in the sky.
Kind of remarkable, and when the plane moves, and flying almost above the ground, he immediately came under fire anti-aircraft aviation.On-screen indicators show the necessary height, including the altitude of enemy aircraft, maps of territory, which runs the mission, and other data.Mission variety.Some need to destroy enemy buildings or to move into high-speed aircraft to provide modes shooter.We'll have to fly at low altitude through the narrow canyons, to maneuver in a rather complex spaces.
Objectives of the mission will be able to learn in text messages on the screen during the flight.At your disposal 9 unique aircraft, from which you can make your choice, but some missions have to perform on a particular plane.In aircraft of different speed, maneuverability, engine power, strength, armor, and enemies are also not born yesterday.Players in battle using machine guns and homing missiles.Ground anti-aircraft artillery is a serious danger, and sometimes, when you need to fly at low altitude, it is difficult to dodge the missile system surface-to-air, as well as other hazards.
1)Unpack
2)install :C or :E
#VBAGX no need register already Cr@ck​
6,787
29,884
A Sound of Thunder Game Boy Advance
A Sound of Thunder
It takes place in the near future.It happened a fantastic invention, discover the secret of time travel, and travel company provides
absolutely wonderful entertainment: go for a million years into the past.The game follows the plot of the famous movie, and we must abide by the three most important rules: do not change anything in the past, do not leave anything behind and not bring anything in the present.Maybe someone from the tourists did not take these rules seriously violated them, as a result of the passage of time was distorted, and this occurred catastrophic changes.A new evolutionary branch, resulting in a variety of mutants, and the main character Travis Raer must find out why the changes had occurred and to save humanity from destruction.
Players examined territory, fight with enemies, solve tactical puzzles.The main character armed with a special device, freezing time (Time Freeze Disruptor), resulting in time very slowly, and battles take place at normal speed.
1)Unpack
2)install :C or :E
