سوال: ریکاوری با Hiren boot Cd 9.5
alone42000
13
یه نفرو میشناسم که ریکاوری رو با Hiren boot Cd 9.5 انجام میده و معمولا 90% تمام فایلها رو برمیگردونه ولی توی هایرن چند تا نرم افزار برای ریکاوری هست کی میدونه کدومشون با چه تنظیماتی هست ؟
akbarof
206
1,821
خوزستان
اینم لیست همه محتویات
Hiren boot Cd 9.5
[hide]
[h=2]Antivirus Tools[/h]
  • [*=left]F-Prot Antivirus 3.16f (1410): Very good virus scanner (with ntfs support and easy to use menu).
    [*=left]McAfee Antivirus 4.4.50 (1410): A virus scanner (with ntfs support and easy to use menu).
[h=2]BIOS / CMOS Tools[/h]
  • [*=left]!BIOS 3.20: A powerfull utility for bios and cmos.
    [*=left]Award DMI Configuration Utility 2.43: DMI Configuration utility for modifying/viewing the MIDF contents.
    [*=left]BIOS Cracker 1.4: BIOS password remover (cmospwc).
    [*=left]BIOS Cracker 4.8: BIOS password remover (cmospwd).
    [*=left]BIOS Utility 1.35.0: BIOS Informations, password, beep codes and more.
    [*=left]CMOS 0.93: CMOS Save / Restore Tool.
    [*=left]DISKMAN4: A powerful all in one utility.
    [*=left]Kill CMOS: A tiny utility to wipe cmos.
    [*=left]UniFlash 1.40: Bios flash utility.
[h=2]Disk Clone Tools[/h]
  • [*=left]Acronis True Image 8.1.945: Create an exact disk image for complete system backup and disk cloning.
    [*=left]COPYR.DMA Build013: A Tool for making copies of hard disks with bad sectors.
    [*=left]ImageCenter 5.6 (Drive Image 2002): Best software to clone hard drive.
    [*=left]Norton Ghost 11.0.1: Similar to Drive Image (with usb/scsi support).
    [*=left]Partition Saver 3.50: A tool to backup/restore partitions.
[h=2]Dos File Managers[/h]
  • [*=left]Dos Command Center 5.1: Classic dos-based file manager.
    [*=left]Dos Navigator 6.4.0: Dos File Manager, Norton Commander clone but has much more features.
    [*=left]FastLynx 2.0: Dos file manager with Pc to Pc file transfer capability.
    [*=left]File Maven 3.5: An advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable.
    [*=left]File Wizard 1.35: A file manager: colored files, drag and drop copy, move, delete etc.
    [*=left]LapLink 5.0: The smart way to transfer files and directories between PCs.
    [*=left]Mini Windows 98: Can run from Ram Drive, with ntfs support, Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc…
    [*=left]Volkov Commander 4.99: Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander).
[h=2]Dos Tools[/h]
  • [*=left]1394 Firewire Support: 1394 Firewire Drivers for Dos.
    [*=left]Interlnk support at COM1: To access another computer from COM port.
    [*=left]Interlnk support at LPT1: To access another computer from LPT port.
    [*=left]SATA Support: SATA Driver (gcdrom.sys) and JMicron JMB361 (xcdrom.sys) for Dos.
    [*=left]SCSI Support: SCSI Drivers for Dos.
    [*=left]Universal USB Driver 2: Panasonic v2.20 ASPI Manager for USB mass storage.
    [*=left]USB CD-Rom Driver 1: Standard usb_cd.sys driver for cd drive.
[h=2]Hard Disk Tools[/h]
  • [*=left]Active Kill Disk 4.1: Securely overwrites and destroys all data on physical drive.
    [*=left]ExcelStor’s ESTest 4.20
    [*=left]Fujitsu HDD Diagnostic Tool 7.00
    [*=left]Fujitsu IDE Low Level Format 1.0
    [*=left]Gateway GwScan 5.12
    [*=left]Hard Disk Sentinel 0.01: Hard Disk health, performance and temperature monitoring tool.
    [*=left]HDAT2 4.6b: Main function is testing and repair (regenerates) bad sectors for devices.
    [*=left]HDD Eraser 1.0: Secure erase using a special feature built into most newer hard drives.
    [*=left]HDD Regenerator 1.51: To recover a bad hard drive.
    [*=left]IBM/Hitachi Drive Fitness Test 4.11
    [*=left]IBM/Hitachi Feature Tool 2.08
    [*=left]Maxtor (or any Hdd) Low Level Formatter 1.1
    [*=left]Maxtor amset utility 4.0
    [*=left]Maxtor PowerMax 4.23
    [*=left]MHDD 4.6
    [*=left]Norton Disk Doctor 2002: A tool to repair a damaged disk, or to diagnose your hard drive.
    [*=left]Norton Disk Editor 2002: A powerful disk editing, manual data recovery tool.
    [*=left]Ontrack Disk Manager 9.57: Disk Test/Format/Maintenance tool.
    [*=left]Samsung Disk Diagnose (SHDIAG) 1.28
    [*=left]Samsung HDD Utility (HUTIL) 2.04
    [*=left]Seagate Seatools Desktop Edition 3.02
    [*=left]SeaTools for Dos 1.09
    [*=left]SmartUDM 2.00: Hard Disk Drive S.M.A.R.T. Viewer.
    [*=left]Toshiba Hard Disk Diagnostic 2.00b
    [*=left]Victoria 3.33e and 3.52rus: A freeware program for low-level HDD diagnostics.
    [*=left]WDClear 1.30
    [*=left]Western Digital Data Lifeguard Tools
    [*=left]Western Digital Diagnostics (DLGDIAG) 5.04f
[h=2]MBR (Master Boot Record) Tools[/h]
  • [*=left]Boot Partition 2.60: Add Partition in the Windows NT/2000/XP Multi-boot loader.
    [*=left]BootFix Utility: Run this utility if you get ‘Invalid system disk’.
    [*=left]Bootmagic 8.0: This tool is for multi boot operating systems.
    [*=left]DiskMan4: Al in one tool for cmos, bios, bootrecord and more.
    [*=left]MBR SAVE / RESTORE 2.1: BootSave and BootRest tools to save / restore MBR.
    [*=left]MBR Tool 2.2.100: Backup, verify, restore, edit, refresh, remove, display, re-write…
    [*=left]MBR Work 1.07b: A utility to perform some common and uncommon MBR functions.
    [*=left]MBRWizard 2.0b: Directly update and modify the MBR (Master Boot Record).
    [*=left]Partition Table Doctor 3.5: A tool to repair/modify mbr, bootsector, partition table.
    [*=left]Smart Boot Manager 3.7.1: A multi boot manager.
[h=2]MultiMedia Tools[/h]
  • [*=left]MpxPlay 1.56: A small Music Player for dos.
    [*=left]Picture Viewer 1.94: Picture viewer for dos, supports more then 40 filetypes.
    [*=left]QuickView Pro 2.58: Movie viewer for dos, supports many format including divx.
[h=2]NTFS Ext2FS, Ext3FS (FileSystems) Tools[/h]
  • [*=left]EditBINI 1.01: To Edit boot.ini on NTFS Partition.
    [*=left]NTFS 4 Dos 1.9: To access ntfs partitions from Dos.
    [*=left]NTFS Dos 3.02: To access ntfs partitions from Dos.
    [*=left]NTFS Dos Pro 5.0: To access ntfs partitions from Dos.
    [*=left]Paragon Mount Everything 3.0: To access NTFS, Ext2FS, Ext3FS partitions from dos.
[h=2]Other Tools[/h]
  • [*=left]DosCDroast beta 2: Dos CD Burning Tools.
    [*=left]Ghost Walker 2003.793: Utility that changes the security ID (SID) for Windows NT, 2000 and XP.
    [*=left]Universal TCP/IP Network 6.2: MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 85 different network card drivers.
[h=2]Password Tools[/h]
  • [*=left]Active Password Changer 3.0.420: To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS).
    [*=left]ATAPWD 1.2: Hard Disk Password Utility.
    [*=left]NTPWD: Utility to reset windows nt/2000/xp administrator/user password.
    [*=left]Offline NT/2K/XP Password Changer: utility to reset windows nt/2000/xp administrator/user password.
    [*=left]Registry Reanimator v1.02: Check and restore structure of the damaged registry files of NT/2K/XP.
    [*=left]Registry Viewer 4.2: Registry Viewer/Editor for Win9x/Me/NT/2K/XP.
[h=2]Partition Tools[/h]
  • [*=left]Acronis Disk Director Suite 9.0.554: Popular disk management functions in a single suite.
    [*=left]eXtended Fdisk 0.9.3: XFDISK allows easy partition creation and edition.
    [*=left]GDisk 1.1.1: Complete replacement for the DOS FDISK utility and more.
    [*=left]Paragon Partition Manager 7.0.1274: Universal tool for partitions.
    [*=left]Partition Commander 9.01: The safe way to partition your hard drive,with undo feature.
    [*=left]Partition Magic Pro 8.05: Best software to partition hard drive.
    [*=left]Ranish Partition Manager 2.44: A boot manager and hard disk partitioner.
    [*=left]Smart Fdisk 2.05: A simple harddisk partition manager.
    [*=left]SPecial Fdisk 2000.03t: SPFDISK A partition tool.
    [*=left]Super Fdisk 1.0: Create, delete, format partitions drives without destroying data.
    [*=left]The Partition Resizer v1.3.4: Move and resize your partitions in one step and more.
[h=2]RAM (Memory) Testing Tools[/h]
  • [*=left]DocMemory 3.1b: RAM Test utility.
    [*=left]GoldMemory 5.07: RAM Test utility.
    [*=left]Memtest86+ 2.00: PC Memory Test.
[h=2]Recovery Tools[/h]
  • [*=left]Active Partition Recovery 3.0: To Recover a Deleted partition.
    [*=left]Active Uneraser 3.0: To recover deleted files and folders on FAT and NTFS systems.
    [*=left]DiyDataRecovery Diskpatch 2.1.100: An excellent data recovery software.
    [*=left]Lost & Found 1.06: A good old data recovery software.
    [*=left]Ontrack Easy Recovery Pro 6.10: To Recover data that has been deleted/virus attack.
    [*=left]PhotoRec 6.9b: File and pictures recovery Tool.
    [*=left]Prosoft Media Tools 5.0 v1.1.2.64: Another excellent data recovery software with many other options.
    [*=left]TestDisk 6.9b: Tool to check and undelete partition.
    [*=left]Winternals Disk Commander 1.1: More than just a standard deleted-file recovery utility.
[h=2]System Information Tools[/h]
  • [*=left]Aida16 2.14: A system information tool, extracts details of all components of the PC.
    [*=left]Astra 5.34: Advanced System info Tool and Reporting Assistant.
    [*=left]CPU Identification utility v1.12: Detailed information on CPU (CHKCPU.EXE).
    [*=left]CTIA CPU Information: Another CPU information tool.
    [*=left]HwInfo 5.1.0: A powerful system information utility.
    [*=left]Navratil Software System Information 0.59.16: High-end professional system information tool.
    [*=left]PC-Config 9.33: Complete hardware detection of your computer.
    [*=left]PCI and AGP info Tool (1410): The PCI System information & Exploration tool.
    [*=left]SysChk 2.46: Find out exactly what is under the hood of your PC.
    [*=left]System Analyser version 5.3t: View extensive information about your hardware.
[h=2]Testing Tools[/h]
  • [*=left]Ontrack Data Advisor 5.0: Powerful diagnostic tool for assessing the condition of your computer.
    [*=left]PC Doctor 2004: A benchmarking and information tool.
    [*=left]PC-Check 6.0: Easy to use hardware tests.
    [*=left]System Speed Test 4.78: It tests CPU, harddrive, etc.
    [*=left]Test Cpu/Video/Disk 5.6: A tool to test cpu, video, and disk.
    [*=left]Test Hard Disk Drive 1.0: A tool to test Hard Disk Drive.
    [*=left]The Troubleshooter 7.02: All kind of hardware testing tool.
[h=2]Windows Tools[/h]
  • [*=left]Active Undelete 5.5: A tool to recover deleted files.
    [*=left]Ad-Aware SE Personal 1.06 (1410): Find and remove spyware, adware, dialers etc. (a must have tool).
    [*=left]Autoruns 9.12: Displays All the entries from startup folder, Run, RunOnce, and other Registry keys, Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications, auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers and much more which helps to remove nasty spyware/adware and viruses.
    [*=left]CCleaner 2.04.543: Crap Cleaner is a freeware system optimization and privacy tool.
    [*=left]Content Advisor Password Remover 1.0: It Removes Content Advisor Password from Internet Explorer.
    [*=left]CPU-Z 1.44: It gathers information on some of the main devices of your system.
    [*=left]CurrPort 1.20: Displays the list of all currently opened TCP and UDP ports on your computer.
    [*=left]CWShredder 2.19: Popular CoolWebSearch Trojan Remover tool.
    [*=left]Data Shredder 1.0: A tool to Erase disk and files (also wipe free space) securely.
    [*=left]DefragNT 1.9: This tool presents the user with many options for disk defragmenting.
    [*=left]Dial a Fix 0.60.0.24: Fix errors and problems with COM/ActiveX object errors and missing registry entries, Automatic Updates, SSL, HTTPS, and Cryptography service (signing/verification) issues, Reinstall internet explorer etc. comes with the policy scanner.
    [*=left]Disk Speed 1.0: Hard Disk Drive Speed Testing Tool.
    [*=left]Double Driver 1.0: Driver Backup and Restore tool.
    [*=left]Drive SnapShot 1.38: Creates an exact Disk Image of your system into a file while windows is running.
    [*=left]Drive Temperature 1.0: Hard Disk Drive temperature meter.
    [*=left]DriveImage Explorer 5.0: To add/remove/extract files from Drive image file.
    [*=left]DriverBackup! 1.0.3: Another handy tool to backup drivers.
    [*=left]Express Burn 4.06: CD/DVD Burner Program to create and record CDs/DVDs, also create/burn .iso and .nrg images.
    [*=left]EzPcFix 1.0.0.16: Helpful tool when trying to remove viruses, spyware, and malware.
    [*=left]GetDataBack for FAT 2.31: Data recovery software for FAT file systems.
    [*=left]GetDataBack for NTFS 2.31: Data recovery software for NTFS file systems.
    [*=left]Ghost Image Explorer 11.0.1: To add/remove/extract files from Ghost image file.
    [*=left]HDD Scan 2.8: This is a Low-level HDD diagnostic tool, it scans surface find bad sectors etc.
    [*=left]HijackThis 2.0.2: A general homepage hijackers detector and remover and more.
    [*=left]IB Process Manager 1.04: A little process manager for 9x/2k, shows dll info etc.
    [*=left]JkDefrag 3.34: Free disk defragment and optimize utility for Windows 2000/2003/XP/Vista.
    [*=left]MemTest 1.0: A Memory Testing Tool.
    [*=left]Monitor Tester 1.0: Allows you to test CRT/LCD/TFT screens for dead pixels and diffective screens.
    [*=left]NewSID 4.10: Utility that changes the security ID (SID) for Windows NT, 2000 and XP.
    [*=left]NT Registry Optimizer 1.1j: Registry Optimization for Windows NT/2000/2003/XP/Vista.
    [*=left]PageDfrg 2.32: System file Defragmenter For NT/2k/XP.
    [*=left]Partition Find and Mount 2.3: Partition Find and Mount software is designed to find lost or deleted partitions.
    [*=left]PC Wizard 2008 1.83: Powerful system information/benchmark utility designed especially for detection of hardware.
    [*=left]PCI 32 Sniffer 1.1 (1410): Device information tool (similar to unknown devices).
    [*=left]Pocket KillBox 2.0.0.978: Can be used to get rid of files that stubbornly refuse to allow you to delete them.
    [*=left]Process Explorer 11.04: Shows you information about which handles and DLLs processes have opened or loaded.
    [*=left]ProduKey 1.20: Recovers lost the product key of your Windows/Office.
    [*=left]Recuva 1.10.223: Restore deleted files from Hard Drive, Digital Camera Memory Card, usb mp3 player…
    [*=left]Restoration 2.5.14: A tool to recover deleted files.
    [*=left]RootkitRevealer 1.7: Rootkit Revealer is an advanced patent-pending root kit detection utility.
    [*=left]S&M Stress Test 1.9.1: CPU/HDD/Memory benchmarking and information tool, including temperatures/fan speeds/voltages.
    [*=left]Shell Extensions Manager (ShellExView) 1.19: An excellent tool to View and Manage all installed Context-menu/Shell extensions.
    [*=left]Silent Runners Revision 55: A free script that helps detect spyware, malware and adware in the startup process.
    [*=left]SmitFraudFix 2.289: This removes Some of the popular Desktop Hijack malware.
    [*=left]SpaceMonger 1.4: Keeping track of the free space on your computer.
    [*=left]Spybot: Search & Destroy 1.5.2 (1410): Application to scan for spyware, adware, hijackers and other malicious software.
    [*=left]SpywareBlaster 3.5.1 (1410): Prevent the installation of spyware and other potentially unwanted software.
    [*=left]Startup Control Panel 2.8: A tool to edit startup programs.
    [*=left]Startup Monitor 1.02: It notifies you when any program registers itself to run at system startup.
    [*=left]TweakUI 2.10: This PowerToy gives you access to system settings that are not exposed in the Windows Xp.
    [*=left]Unknown Devices 1.2 (1410): Helps you find what those unknown devices in Device Manager really are.
    [*=left]Unlocker 1.8.5: This tool can delete file/folder when you get this message: Cannot delete file: Access is denied, The file is in use by another program etc.
    [*=left]Unstoppable Copier 3.12: Allows you to copy files from disks with problems such as bad sectors, scratches or that just give errors when reading data.
    [*=left]WhitSoft File Splitter 4.5a: A Small File Split-Join Tool.
    [*=left]WinDirStat 1.1.2.80: A disk usage statistics viewer and cleanup tool for Windows.
    [*=left]WinKeyFinder 1.73: Allows you to View and Change Windows XP/2003 Product Keys, backup and restore activation related files, backup Microsoft Office 97, 2000 SP2, XP/2003 keys etc.
    [*=left]Winsock 2 Fix for 9x: To fix corrupted Winsock2 information by poorly written Internet programs.
    [*=left]Wireless Key View 1.15: Recovers all wireless network keys (WEP/WPA) stored in your computer by WZC.
    [*=left]XP TCP/IP Repair 1.0: Repair your Windows XP Winsock and TCP/IP registry errors.
    [*=left]Xp-AntiSpy 3.96.7: It tweaks some Windows XP functions, and disables some unneeded Windows services quickly.
[/hide]
elektera
28
63
سلام خدمت دوستان من برنامه رو دارم اما متاسفانه کپی شده از روی سی دی هست من کپی کردم روی یه سی دی دیگه اما به صورت بوت بالا نیومد.من چطور میتونم این برنامه رو یا با سی دی یا فلش به صورت بوت اجرا کنم؟
A.R.T
3,172
46,442
شما فقط اون فایل را رایت کردید
در صورتی که سی دی هایرن دارای فایلهای بوت هست
پس باید یا فلش یا سی دی خود را بوتیبل کنید
توی همین سایت راه و روش بوت کردن فلش به بصورت کامل توضیح داده شده
