تاكي واكي با ماژول rfm12b
as3
اگه كسي اطلاعات در مورد ساخت تاكي واكي با ماژول rfm12 داره ( مدار و برنامه ) لطفا كمك
jfrras
مدير انجمن تخصصی الکترونیک
3,189
74,250
49
دوست عزیز این ماژول ها مخصوص انتقال دیتاست. برای صوت طراحی نشده.
[h=2]RFM12 - Wireless Transceiver Module Demo[/h]
[h=3]Description[/h]
This project shows how to do wireless communication with the RFM12 tranceiver modue in combination with a PIC microcontroller.
The RFM12 is a low costing ISM band FSK transceiver module. There are different module variants available which support different frequency bands: 315/433/868/915MHZ. The module has an SPI interface for communication with a microcontroller.
For this demo project I used a PIC18F458 and a RFM12 module with 433 MHz. But with some small modifications it will also work for other PIC micros or RFM12 moduls with other frequency bands.
[h=3]Hardware[/h]
The connection of the RFM12 tranceiver module is very simple. It just needs
  • a power supply (2.2V - 5.4V)
  • a 10k pull-up to Vdd on the FSK/DATA/nFFS pin
  • antenna (simple wire with 17 cm length for 433MHz)
  • 4 pins for SPI communication (SDI, SDO, SCK, nSEL)
  • optinal: one interrupt pin (nIRQ, not used in this demo)
For this demo two microcontroller boards with one RFM12 on each board is required. One acts as transmitter, the other one as receiver.
[h=3]Software[/h]
The driver which is used in this project is mainly based on a RFM12 driver written for an AVR microcontroller (see link).
I have ported the code to the PIC world. The driver can be compiled with the CCS C compiler and the Microchip C18 compiler.
[h=4]Driver Configuration[/h] If you use the RFM12 driver in your project, you might use another PIC or use different pins for the connection of the RFM12 module. For configuring the driver to your project needs, you need to adapt the driver configuration header file rfm12conf.h.
Here an example configuration for this demo project. For each pin of the RFM12 module which needa to be controlled there is a macro for setting/clearing/reading a pin of the RFM12 module. Depending on your hardware configuration you need to update this file.
Note: As you can see, the configuration of the driver is dependend on the used compiler.
#ifndef _RFM12CONF_H #define _RFM12CONF_H /*---------------------------------------------------------------------------*/ /* Configuration for Microchip C18 Compiler */ /*---------------------------------------------------------------------------*/ #if defined(__18CXX) #include /* set I/O direction for pins used for controlling RFM12 */ #define RFM12_PinInit() LATD &= 0x1F; TRISD &= 0x1F; /* I/O pin controll functions */ #define RFM12_ClrSCK() LATDbits.LATD7 = 0 #define RFM12_SetSCK() LATDbits.LATD7 = 1 #define RFM12_ClrSDI() LATDbits.LATD6 = 0 #define RFM12_SetSDI() LATDbits.LATD6 = 1 #define RFM12_ClrNSEL() LATDbits.LATD5 = 0 #define RFM12_SetNSEL() LATDbits.LATD5 = 1 #define RFM12_GetSDO() PORTDbits.RD4 #define RFM12_GetIRQ() PORTDbits.RD3 #endif /* #if defined(__18CXX) */ /*---------------------------------------------------------------------------*/ /* Configuration for CCS C Compiler */ /*---------------------------------------------------------------------------*/ #if (defined(__PCB__) || defined(__PCH__) || defined(__PCM__)) /* set I/O direction for pins used for controlling RFM12 */ #define RFM12_PinInit() /* not required for CCS C Compiler */ /* I/O pin controll functions */ #define RFM12_ClrSCK() output_low(PIN_D7) #define RFM12_SetSCK() output_high(PIN_D7) #define RFM12_ClrSDI() output_low(PIN_D6) #define RFM12_SetSDI() output_high(PIN_D6) #define RFM12_ClrNSEL() output_low(PIN_D5) #define RFM12_SetNSEL() output_high(PIN_D5) #define RFM12_GetSDO() input(PIN_D4) #define RFM12_GetIRQ() input(PIN_D3) #endif /* (defined(__PCB__) || defined(__PCH__) || defined(__PCM__)) */ #endif /* #define _RFM12CONF_H */ [h=4]Driver Initialization[/h] The usage of the driver is also very simple. During init, the following driver functions need to be called. The parameters can be adjusted to your project needs. For more details regarding the functions check the driver code.
RFM12_Init(); RFM12_SetFreq(RFM12FREQ(433.92)); /* Rx/Tx frequency 433.92MHz */ RFM12_SetBandwidth(4, 1, 4); /* 200kHz Bandwidth, -6dB LNA gain, */ /* (DRSSI threshold: -79dBm */ RFM12_SetBaud(19200); /* 19200 baud */ RFM12_SetPower(0, 6); /* 1mW output power, 120kHz frequency shift */ [h=4]Transmit Data[/h] To transmit data, you just need to call the RFM12_TxData function with the buffer to be transmitted and the buffer length as parameter:
uint8 txbuf[] = "*** Hello World! RFM12 Demo! ***"; RFM12_TxData(txbuf, sizeof(txbuf); [h=4]Receive Data[/h] To receive data, you just need to call the RFM12_RxData function with the buffer for receiving the data and the number of bytes to be read:
uint8 rxbuf[32]; RFM12_RxData(rxbuf, 32);
[h=3]Running the RFM12 Demo[/h]
To run the demo, just load download the demo and open the project with your CCS C compiler or the Microchip C18 compiler. Some adaptions in the compiler project might be necessary due to different path settings.
To compile the receiver, just enable the MODE_RECEIVER #define and disable the MODE_TRANSMITTER #define.
#define MODE_RECEIVER //#define MODE_TRANSMITTER To compile the transmitter, just disable the MODE_RECEIVER #define and enable the MODE_TRANSMITTER #define.
//#define MODE_RECEIVER #define MODE_TRANSMITTER Here some pictures of the demo hardware.
reza_476
4,007
45,330
با سلام و کسب اجازه از اساتید، ماژول اشاره شده شما قابلیت ارسال و دریافت صوت را ندارند اگر بخواهید از ماژولهای زیر استفاده کنید:
TX FM AUDIO و RX FM AUDIO و با فرکانس 433 مگاهرتز کار میکنند.
ebi1391
14
پروژه واکی تاکی با rfm12یکی از کاربردهای مهم این ماژول هاست و خیلی هم زیاد موجوده در صورتی که نتونستین پیدا کنین براتون بزارم :63000000:
mohsen++
141
636
بله قابلیت ارسال صوت رو ندارند ولی میتونین صوت رو تبدیل به دیتا کنین و با استفاده از این ماژولها ارسال کنین همون کاری که تلفنهای موبایل و سویچهای دیجیتال تلفن انجام میدند
reza_476
4,007
45,330
باسلام چطوری میتوان صوت را به دیتا تبدیل کرد.
mohsen++
141
636
یک مقداری این قضیه طولانیه ولی خلاصه کار اینه :
در جهت ارسال : یک مدار a to d در فاصله زمانی مشخص مثلا هر ثانیه 8000 بار نمونه بر میداره و اونو بصورت داده های هشت بیتی در میاره قبل از مدار نمونه بردار هم یک ***** پایین گذر با فرکانس کمتر از نصف فرکانس یا همون سرعت نمونه برداری در اینجا حدود 3.4 کیلو هرتز قرار داده میشه ( در چنین سرعتهایی این مبدل آنالوگ به دیجیتال میتونه a to d داخلی میکرو باشه )
در جهت دریافت یک مدار d to a اطلاعات دیجیتال دریافت شده که هر 125 میکرو ثانیه ( هر ثانیه 8000 تا ) از راه میرسند رو تبدیل به مقادیر آنالوگ میکنه و بعد از عبور از یک ***** با فرکانس کمتر از نصف فرکانس نمونه برداری سیگنال آنالوگ بازیابی میشه
البته چون در اینجا سرعت نمونه برداری 8000 نمونه بر ثانیه بوده و بنابر این ناچار به استفاده از ***** پایین گذر با فرکانس کمتر از نصف این فرکانس هستیم ( 3.4 کیلو هرتز ) کیفیت صوت بازیابی شده در حد کیفیت صوت تلفنی خواهد بود .
برای کیفیتهای بالاتر سرعت نمونه برداری و همچنین تعداد بیت های تخصیص داده به هر نمونه رو بالاتر میبرند و همچنین فرکانس ***** پایین گذر رو نیز متناسب با سرعت نمونه برداری افزایش میدند
بصورتیکه برای کیفیت cd سرعت نمونه برداری به 44000 نمونه بر ثانیه میرسه
پانوشت : در سیستمهای جدید بعد از نمونه برداری یک سری عملیات (کدینگ در جهت ارسال و دیکینگ در جهت دریافت )هم بر روی اطلاعات دیجیتال انجام میشه تا حجم اطلاعات دیتا به حداقل برسه ( شبیه عملیاتی که مثلا اطلاعات wave رو به mp3 تبدیل میکنه )
