ali8889
- 1389٫7٫30
- 447
- 1,823
با سلام خدمت اساتید میخواستم بدونم این وسیله چه کاربردی دارد
AC Voltage Detector
BasicFunction
1- Self testing before use : Close the tester probe to any hot line . bestest II will light up together with buzzer sound . if the light & sound are weak please replace the batteries inside .
2 – Test voltage present . Close the test pin to live parts the tester will light uo together with sound .
3 - Don't place the tester near high voltagewarning.
• Check before use
• Never test the voltage which than 1000v AC
• IP54 , IEC 1010 • AAA 1.5×2
• Battery life : 6 houre for continious using standby for 1.5 years .
AC Voltage Detector
BasicFunction
• Check before use
