مشکل: مشکل بوت نشدن کامل سوئیچ سیسکو مدل 2960x-48FPS-L
jafarttl
VIP PLUS
VIP PLUS
247
296
سلام به همه عزیزان
یه سوئیچ 2960x هست که هنگام بوت شدن پیغام خطای زیر رو نمایش میده ممنون میشم راهنمایی کنید تا مشکل حل بشه:
CPU rev: B
Image passed digital signature verification
Board rev: 18
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:29:ef:36:37:00
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 833536
mifs[5]: Bytes available : 972800
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 971264
mifs[6]: Bytes available : 2899456
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 1 files, 1 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 26862592
mifs[9]: Bytes available : 95323136
mifs[9]: mifs fsck took 32 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-6.E1.bin"...Verifying image flash:c2960x-universalk9-mz.152-6.E1.bin.......................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ...............Image passed digital signature verification
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@Err: Interrupt: Data TLB miss (0x1100).
PC: 0x1f195c14, MSR: 0x00021000, ESR: 0x00800000, DEAR: 0x38600004:
. Data TLB miss on write at 0x38600004 (Caller 0x1f195910).
(Bailed out.)
چندین بار فرمت فلش کردم و مجدد ios ریختم ولی هر بار هنگام بوت شدن با پیغام خطای بالا مواجه می شود.....!!؟؟
مدل سوئیچ WS-C2960X-48FPS-L
jafarttl
VIP PLUS
VIP PLUS
247
296
یعنی واقعا کسی تا حالا با این مشکل مواجه نشده!؟
دوستان موضوع حیاتی هست. اگر واقعا کسی راهکاری میدونه خواهشن بیان کنه تا این مشکل برطرف بشه....
بسیار ممنون میشم...
