مشکل ارور t17
Behzadsf
18
11
هشبرد t17 روی کنترل برد ساپورت نمیکنه من خطا هم پیوست میکنم
Booting Linux on physical CPU 0x0
Linux version 4.6.0-xilinx-gff8137b-dirty (lzq@armdev2) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-23) ) #25 SMP PREEMPT Fri Nov 23 15:30:52 CST 2018
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Xilinx Zynq
cma: Reserved 16 MiB at 0x0e000000
Memory policy: Data cache writealloc
On node 0 totalpages: 61440
free_area_init_node: node 0, pgdat c0b39280, node_mem_map cde10000
Normal zone: 480 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 61440 pages, LIFO batch:15
percpu: Embedded 12 pages/cpu @cddf1000 s19776 r8192 d21184 u49152
pcpu-alloc: s19776 r8192 d21184 u49152 alloc=12*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960
Kernel command line: mem=240M console=ttyPS0,115200 ramdisk_size=33554432 root=/dev/ram rw earlyprintk
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 203752K/245760K available (6345K kernel code, 231K rwdata, 1896K rodata, 1024K init, 223K bss, 25624K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xcf800000 - 0xff800000 ( 768 MB)
lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc090c424 (9234 kB)
.init : 0xc0a00000 - 0xc0b00000 (1024 kB)
.data : 0xc0b00000 - 0xc0b39fe0 ( 232 kB)
.bss : 0xc0b39fe0 - 0xc0b71c28 ( 224 kB)
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to cf800000
ps7-slcr mapped to cf802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at cf802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
ps7-ttc #0 at cf80a000, irq=18
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100058
CPU1: failed to boot: -1
Brought up 1 CPUs
SMP: Total of 1 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xcf880000
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 12584K (cceb7000 - cdb01000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=16 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 158, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to cf86e000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
CAN device driver interface
gpiod_set_value: invalid GPIO
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 31 (00:0a:35:00:00:00)
Generic PHY e000b000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
nand: Micron MT29F2G08ABAGAWP
nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
nand: WARNING: pl35x-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
6 ofpart partitions found on MTD device pl35x-nand
Creating 6 MTD partitions on "pl35x-nand":
0x000000000000-0x000002800000 : "BOOT.bin-env-dts-kernel"
0x000002800000-0x000004800000 : "ramfs"
0x000004800000-0x000005000000 : "configs"
0x000005000000-0x000006000000 : "reserve"
0x000006000000-0x000008000000 : "ramfs-bak"
0x000008000000-0x000010000000 : "reserve1"
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
zynq_pm_ioremap: no compatible node found for 'xlnx,zynq-ddrc-a05'
zynq_pm_late_init: Unable to map DDRC IO memory.
Registering SWP/SWPB emulation handler
hctosys: unable to open rtc device (rtc0)
ALSA device list:
No soundcards found.
RAMDISK: gzip image found at block 0
EXT4-fs (ram0): couldn't mount as ext3 due to feature incompatibilities
EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
random: dd urandom read with 0 bits of entropy available
ubi0: attaching mtd2
ubi0: scanning is finished
ubi0: attached mtd2 (name "configs", size 8 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 24/11, WL threshold: 4096, image sequence number: 567026362
ubi0: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 40
ubi0: background thread "ubi_bgt0d" started, PID 708
UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 711
UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "configs"
UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi0:0): FS size: 1396736 bytes (1 MiB, 11 LEBs), journal size 888833 bytes (0 MiB, 5 LEBs)
UBIFS (ubi0:0): reserved for root: 65970 bytes (64 KiB)
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 88B6B6EE-D353-4240-B0CD-A583D8193BE9, small LPT model
ubi1: attaching mtd5
ubi1: scanning is finished
ubi1: attached mtd5 (name "reserve1", size 128 MiB)
ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi1: good PEBs: 1020, bad PEBs: 4, corrupted PEBs: 0
ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi1: max/mean erase counter: 206/45, WL threshold: 4096, image sequence number: 3056791106
ubi1: available PEBs: 0, total reserved PEBs: 1020, PEBs reserved for bad PEB handling: 36
ubi1: background thread "ubi_bgt1d" started, PID 720
UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 723
UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "reserve1"
UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi1:0): FS size: 123039744 bytes (117 MiB, 969 LEBs), journal size 6221824 bytes (5 MiB, 49 LEBs)
UBIFS (ubi1:0): reserved for root: 4952683 bytes (4836 KiB)
UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 5F57E2BD-5EB5-4F4F-8004-8BC6468A7B83, small LPT model
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
macb e000b000.ethernet eth0: link up (100/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
In axi fpga driver!
request_mem_region OK!
AXI fpga dev virtual address is 0xcfb38000
*base_vir_addr = 0xab013
In fpga mem driver!
fpga mem virtual address is 0xd2000000
2021-10-28 08:32:09 driver-btm-api.c:663:init_freq_mode: This is scan-user version
2021-10-28 08:32:09 driver-btm-api.c:2028:bitmain_soc_init: opt_multi_version = 1
2021-10-28 08:32:09 driver-btm-api.c:2029:bitmain_soc_init: opt_bitmain_ab = 1
2021-10-28 08:32:09 driver-btm-api.c:2030:bitmain_soc_init: opt_bitmain_work_mode = 0
2021-10-28 08:32:09 driver-btm-api.c:2031:bitmain_soc_init: Miner compile time: Thu Apr 23 16:29:07 CST 2020 type: Antminer T17
2021-10-28 08:32:09 driver-btm-api.c:2032:bitmain_soc_init: commit version: 1c5be6f 2020-04-20 16:18:14, build by: lol 2020-04-23 16:35:04
2021-10-28 08:32:09 driver-btm-api.c:1844:show_sn: no SN got, please write SN to /nvdata/sn
2021-10-28 08:32:09 driver-btm-api.c:1167:miner_device_init: Detect 256MB control board of XILINX
2021-10-28 08:32:09 driver-btm-api.c:1115:init_fan_parameter: fan_eft : 0 fan_pwm : 0
2021-10-28 08:32:09 thread.c:885:create_read_nonce_reg_thread: create thread
2021-10-28 08:32:15 driver-btm-api.c:1099:init_miner_version: miner ID : 80722c4815408854
2021-10-28 08:32:15 driver-btm-api.c:1105:init_miner_version: FPGA Version = 0xB013
2021-10-28 08:32:17 eeprom.c:425:check_pattern_test_level: invalid pattern test result. ignore
2021-10-28 08:32:17 driver-btm-api.c:737:get_product_id: product_id[2] = 1
2021-10-28 08:32:17 driver-btm-api.c:1666:get_ccdly_opt: ccdly_opt[2] = 1
2021-10-28 08:32:17 driver-btm-api.c:1919:bitmain_board_init: g_ccdly_opt = 1
2021-10-28 08:32:17 driver-btm-api.c:676:_set_project_type: project:2
2021-10-28 08:32:17 driver-btm-api.c:706:_set_project_type: Project type: Antminer T17
2021-10-28 08:32:17 driver-btm-api.c:717:dump_pcb_bom_version: Chain [2] PCB Version: 0x0100
2021-10-28 08:32:17 driver-btm-api.c:718:dump_pcb_bom_version: Chain [2] BOM Version: 0x0100
2021-10-28 08:32:22 driver-btm-api.c:1939:bitmain_board_init: Fan check passed.
2021-10-28 08:32:24 board.c:36:jump_and_app_check_restore_pic: chain[2] PIC jump to app
2021-10-28 08:32:27 board.c:40:jump_and_app_check_restore_pic: Check chain[2] PIC fw version=0xb9
2021-10-28 08:32:27 thread.c:880:create_pic_heart_beat_thread: create thread
2021-10-28 08:32:27 power_api.c:55:power_init: power init ...
2021-10-28 08:32:27 driver-btm-api.c:1949:bitmain_board_init: Enter 30s sleep to make sure power release finish.
2021-10-28 08:32:27 power_api.c:46:power_off: init gpio907
2021-10-28 08:32:59 power_api.c:232:set_iic_power_to_highest_voltage: setting to voltage: 17.00 ...
2021-10-28 08:33:06 power_api.c:124:check_voltage_multi: retry time: 0
2021-10-28 08:33:08 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:33:08 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:33:08 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:33:09 power_api.c:124:check_voltage_multi: retry time: 1
2021-10-28 08:33:11 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.369433
2021-10-28 08:33:11 power_api.c:97:get_average_voltage: aveage voltage is: 21.369433
2021-10-28 08:33:11 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.37, more than 1.0v diff.
2021-10-28 08:33:12 power_api.c:124:check_voltage_multi: retry time: 2
2021-10-28 08:33:14 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:14 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:14 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:15 power_api.c:124:check_voltage_multi: retry time: 3
2021-10-28 08:33:17 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.381679
2021-10-28 08:33:17 power_api.c:97:get_average_voltage: aveage voltage is: 21.381679
2021-10-28 08:33:17 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:18 power_api.c:124:check_voltage_multi: retry time: 4
2021-10-28 08:33:19 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.357187
2021-10-28 08:33:19 power_api.c:97:get_average_voltage: aveage voltage is: 21.357187
2021-10-28 08:33:19 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:33:20 power_api.c:124:check_voltage_multi: retry time: 5
2021-10-28 08:33:23 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:23 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:23 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:24 power_api.c:124:check_voltage_multi: retry time: 6
2021-10-28 08:33:26 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.363310
2021-10-28 08:33:26 power_api.c:97:get_average_voltage: aveage voltage is: 21.363310
2021-10-28 08:33:26 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:33:27 power_api.c:124:check_voltage_multi: retry time: 7
2021-10-28 08:33:28 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:33:28 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:33:28 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:33:29 power_api.c:124:check_voltage_multi: retry time: 8
2021-10-28 08:33:31 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:31 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:31 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:32 power_api.c:124:check_voltage_multi: retry time: 9
2021-10-28 08:33:35 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:35 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:35 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:36 power_api.c:124:check_voltage_multi: retry time: 10
2021-10-28 08:33:37 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:33:37 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:33:37 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:33:38 power_api.c:124:check_voltage_multi: retry time: 11
2021-10-28 08:33:40 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:40 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:40 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:41 power_api.c:124:check_voltage_multi: retry time: 12
2021-10-28 08:33:43 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.357187
2021-10-28 08:33:43 power_api.c:97:get_average_voltage: aveage voltage is: 21.357187
2021-10-28 08:33:43 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:33:44 power_api.c:124:check_voltage_multi: retry time: 13
2021-10-28 08:33:46 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:33:46 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:33:46 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:33:47 power_api.c:124:check_voltage_multi: retry time: 14
2021-10-28 08:33:49 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.357187
2021-10-28 08:33:49 power_api.c:97:get_average_voltage: aveage voltage is: 21.357187
2021-10-28 08:33:49 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:33:50 power_api.c:124:check_voltage_multi: retry time: 15
2021-10-28 08:33:52 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:52 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:52 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:53 power_api.c:124:check_voltage_multi: retry time: 16
2021-10-28 08:33:55 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:33:55 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:33:55 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:33:56 power_api.c:124:check_voltage_multi: retry time: 17
2021-10-28 08:33:58 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:33:58 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:33:58 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:33:59 power_api.c:124:check_voltage_multi: retry time: 18
2021-10-28 08:34:01 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:34:01 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:34:01 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:02 power_api.c:124:check_voltage_multi: retry time: 19
2021-10-28 08:34:04 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:34:04 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:34:04 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:05 power_api.c:124:check_voltage_multi: retry time: 20
2021-10-28 08:34:07 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.393926
2021-10-28 08:34:07 power_api.c:97:get_average_voltage: aveage voltage is: 21.393926
2021-10-28 08:34:07 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:08 power_api.c:124:check_voltage_multi: retry time: 21
2021-10-28 08:34:10 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.357187
2021-10-28 08:34:10 power_api.c:97:get_average_voltage: aveage voltage is: 21.357187
2021-10-28 08:34:10 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:34:11 power_api.c:124:check_voltage_multi: retry time: 22
2021-10-28 08:34:13 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.369433
2021-10-28 08:34:13 power_api.c:97:get_average_voltage: aveage voltage is: 21.369433
2021-10-28 08:34:13 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.37, more than 1.0v diff.
2021-10-28 08:34:14 power_api.c:124:check_voltage_multi: retry time: 23
2021-10-28 08:34:16 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.375556
2021-10-28 08:34:16 power_api.c:97:get_average_voltage: aveage voltage is: 21.375556
2021-10-28 08:34:16 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:34:17 power_api.c:124:check_voltage_multi: retry time: 24
2021-10-28 08:34:18 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:34:18 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:34:18 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:19 power_api.c:124:check_voltage_multi: retry time: 25
2021-10-28 08:34:22 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.381679
2021-10-28 08:34:22 power_api.c:97:get_average_voltage: aveage voltage is: 21.381679
2021-10-28 08:34:22 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.38, more than 1.0v diff.
2021-10-28 08:34:23 power_api.c:124:check_voltage_multi: retry time: 26
2021-10-28 08:34:25 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.369433
2021-10-28 08:34:25 power_api.c:97:get_average_voltage: aveage voltage is: 21.369433
2021-10-28 08:34:25 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.37, more than 1.0v diff.
2021-10-28 08:34:26 power_api.c:124:check_voltage_multi: retry time: 27
2021-10-28 08:34:27 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.393926
2021-10-28 08:34:27 power_api.c:97:get_average_voltage: aveage voltage is: 21.393926
2021-10-28 08:34:27 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:28 power_api.c:124:check_voltage_multi: retry time: 28
2021-10-28 08:34:30 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.387802
2021-10-28 08:34:30 power_api.c:97:get_average_voltage: aveage voltage is: 21.387802
2021-10-28 08:34:30 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.39, more than 1.0v diff.
2021-10-28 08:34:31 power_api.c:124:check_voltage_multi: retry time: 29
2021-10-28 08:34:34 power_api.c:86:get_average_voltage: chain[2], voltage is: 21.363310
2021-10-28 08:34:34 power_api.c:97:get_average_voltage: aveage voltage is: 21.363310
2021-10-28 08:34:34 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.36, more than 1.0v diff.
2021-10-28 08:34:35 power_api.c:182:set_iic_power_by_voltage: now set voltage to : 17.000000
2021-10-28 08:34:35 driver-btm-api.c:205:set_miner_status: ERROR_POWER_LOST
2021-10-28 08:34:35 driver-btm-api.c:146:stop_mining: stop mining: power set failed!
2021-10-28 08:34:35 thread.c:930:cancel_read_nonce_reg_thread: cancel thread
2021-10-28 08:34:35 driver-btm-api.c:131:killall_hashboard: ****power off hashboard****
CINAPA
826
2,483
تو فایل تکست بفرستین اینطوری معلوم نمی کنه
ولی در کل مشکل از واحد پاور یا ولتاژ هش برد ها داده که اخر سر پاور دان کرده
Max8050
138
825
32
کنترل بردت به پاور نمیتونه دستور بده، اتصالاتت رو بررسی کن احتمالا سیمی چیزی جابجاست
reza5628
100
176
ایپرام از یکی از هشبرد های سالم رید میشه . در کل ایپرام همه هش برد ها باید یه کد داشته باشن.
h_sarghani
246
40
35
مشهد
من پروگرامر tnm 5000 دارم اما ادابتور ایسی ایپیرام هشتبرد ندارم من همیشه از هشتبرد دیگه ایپیرام رو جایگزین میکنم.یک سوال این ارور دقیقا چیه
2021-12-17 17:48:48 thread.c:734:check_temperature: over max temp, pcb temp 42 (max 80), chip temp 115(max 103)
2021-12-17 17:48:48 driver-btm-api.c:205:set_miner_status: ERROR_TEMP_TOO_HIGH
2021-12-17 17:48:48 driver-btm-api.c:146:stop_mining: stop mining: over max temp
Behzadsf
18
11
داستانش این هست یکی از چیپ ها سنسورش که دما باشه مشکل داره خیلیها میرن سنسور تمپ عوض میکنن که شانسی جواب میگیرن ۰۹۳۶۴۵۹۲۹۰۱ واتساپ من هست
