آموزشی: فهرست 10 تا از بهترین مولتی مترهای 2015
mahmod31
1387٫1٫6
218
1,680
[h=1]1. Fluke 117 Electricians True RMS Multimeter[/h]
[h=2]Click here for more details
[/h] Fluke 117 Electricians True RMS Multimeter takes the award for the best multimeter if you are a professional looking for the highest quality multimeter available. Although one of the more expensive commercial multimeters (although you can purchase it for under $200 if you follow our above discounted link) it is ideally suited for applications in need of demanding settings and boasts true-rms for accurate measurements. With an ergonomic design and an easily readable digital display screen, this multimeter can easily be operated single handed and it’s the highest rated multimeter on Amazon with an average rating of 4.7 out of 5.
[h=1]2. Fluke 115 Compact True-RMS Digital Multimeter[/h]
[/h] Coming very close to the first place, and we actually went back and forth a couple of times analysing these top 2 multimeters, comes a similar model from Fluke, the Fluke 115 Compact True-RMS digital multimeter. Able to perform diode testing and check frequency, continuity and capacitance, this true-RMS multimeter is able to measures 20 A and it’s Category III 600 V safety rated. It can be purchased at a slightly lower price (under $150 or so) but it has almost the same accuracy and precision as the first model.
[h=1]3. Klein Tools MM200 Auto Ranging Multimeter[/h]
[/h] The Klein MM200 auto ranging multimeter is the first one not manufactured by Fluke in our top 10 multimeters list and an order of magnitude more affordable. While the Fluke multimeters are well over $100, you can purchase this particular Klein multimeter for around $50 so even if you are not a professional engineer and just an enthusiast that likes to use professional tools, you can still afford it. It has auto ranging voltage and can measure 600 V AC/DC voltage and 10 Amps AC/DC Current. Features an easily readable, backlit digital display.
[h=1]4. Extech EX330 Autoranging Mini Multimeter[/h]
[/h] The Extech EX330 is a modern looking multimeter, but its cool design is not the reason we included it on our top 10 list. It is the first multimeter that has a built in type K temperature probe and a built in non-contact voltage detector. It has a protective rubber holster and similar to the first mutlimeter we reviewed, has a CAT III UL safety rating.
[h=1]5. Klein Tools MM1000 Electrician’s Multimeter[/h]
[/h] This has been touted as an improvement over the Klein MM200 multimeter, but we haven’t seen that many benefits to justify its increase in price. It’s able to measure 1000 Volts AC/DC voltage and 10 Amps current with auto ranging and it’s slightly more expensive than the 200MM model. Comes with a thermocouple, batteries and test leads.
[h=1]6. Mastech MS8268 Digital AC/DC Auto/Manual Range Multimeter[/h]
[/h] Mastech came up with a line of high quality multimeters, especially the newest MS8268 digital model which impresses with its ability to compete with the Fluke’s models in terms of quality in some aspects but at just a fraction of the cost. It boasts a couple of nice features such as backlit display panel, automatically powering off and audio and visual warnings for the jacks in case they are incorrectly used, but what really makes it a worthwhile purchase is its price: at just $25 only if you purchase it through our discount link above, this is a must buy for everyone looking to purchase a multimeter on a budget.
[h=1]7. Klein Tools MM100 Manual Ranging Multimeter[/h]
[/h] The “little brother
