.این دو تا رو تو لینک http://flashboot.ru/iflash.html وارد می کنید نرم افزار متناسب اون برند فلش رو به شما معرفی می کنه در کل دردسر زیاد داره و ممکنه باز این اتفاق برای اون فلش ریفر و غیر برند بیافته من باشم وقت نمی زارم خیلی زحمت داره و باز هم ممکنه اون مموری همین بلا سرش بیاد تجربه کردم:
However this procedure varies for all USB Flash Drives. Most Mass Production tools are used to repair USB Flash Drives or to add or remove CDFS Partition; Some of these MP Tools can also be used to add/remove write protection. The general procedure to reprogram your USB Flash Drive to add/remove write protection is as follows: Download and Run Chipgenius and find out the VID and PID of your USB Drive. http://agnipulse.com/2010/03/chipgenius-and-usbdeview-usb-information-tools/ Go to http://flashboot.ru/iflash.html and enter the VID and PID of your USB Drive.Check if there are any MassProduction tools available and download them. Then you will have to figure how to use it. Check this for detailed guide on how to do this.(In this guide the MPtool is being used to repair a fake USB Drive) http://agnipulse.com/2010/04/how-i-fixed-a-fake-64gb-usb-drive/ Warning - The procedure varies for different USB Flash Drives and you may end up with irreparable USB Flash Drive. Note: I have successfully used MPTools on Transcend Jetflash USB Drives for various purposes such as flipping the removable bit or adding a cdfs partition. The MPtool for JetFlash USB Drives is called AlcorMptool and this MpTool has the option to flip the removable bit. Another reason why I feel comfortable to use JetFlash USB Drives is because it can be fixed easily if something goes wrong. http://agnipulse.com/2010/04/jetflash-online-recovery-repair-your-transcend-usb-drives-for-free/
