با این برنامه SMS هاتون رو در PC تایپ کنید و با گوشی بفرستید FromSMS v1.02
partizan
71
76
FromSMS v1.02
FromSMS v1.02 {Turn your device into SMS interface for your web application}update
با این برنامه SMS هاتون رو در PC تایپ کنید و با گوشی بفرستید...
FromSMS v1.02{Turn your S60 device into SMS interface for your web application}
FromSMS Client 1.02 released - support for extended character set added.
When your web application needs to send and/or receive SMS messages cost-efficiently, FromSMS is the solution for you. FromSMS offers a simple HTTPS POST interface for sending of SMS messages - all you need is an S60 mobile device with free FromSMS Client installed.
Using FromSMS you avoid issues related to SMS roaming - you select SIM card and operator you want to use for sending and receiving SMS messages.
To keep you in control of costs, you can restrict number of sent SMS messages in FromSMS Client. It also allows you to set blacklist and whitelist for recipient numbers. To decrease data costs, FromSMS Client can use WLAN connection to FromSMS Server.
http://img171.imageshack.us/img171/5...schema3eg1.png
http://img171.imageshack.us/img171/f...png/1/w780.png
کد:
In order to use FromSMS for sending out SMS messages:
    * 1) Download and install FromSMS Client
      2) Send HTTPS POST request with the following syntax:
     	Code:
 	* [URL]https://ssl.fromsms.net/send.php[/URL]
      acode = [account code given to you by FromSMS Client], for example "f8er95kztk98"
      number = [phone number of the recipient], for example "+3461234567"
      message = [SMS message content], for example "Hello world[/CODE
پسوورد فایل:irantk[/CENTER]
