زیباترین پلیر صوتی موبایل TTPOD v3.70
6,787
29,884
TTPOD v3.70 Alfa 13 S60v3 Datecode 10.3.2010 Cr@cked & En Translated Nima79@FOXPDA
TTPOD v3.70 Alfa 13 S60v3 Datecode 10.3.2010 Cr#cked & En Translated Nima79@FOXPDA
UPDATE 10.3.2010 TTPod !!
Change log :
Close the font smoothing
Optimization if they had screen switching speed of
Sort to remove pairs of letters case-sensitive
N73 mask environmental sound and bass boost display
Shielding N95 Night mode display
This problem is fixed:
Horizontal screen repair following the withdrawal, lack of access to a point of order
Adjust the volume repair N73 crash when the problem
Some models fix the problem of sleep shutdown mode is invalid
Restoration progress bar handles the problem follow the animation can not be displayed
Repair opening night mode, locks the keyboard and press left button, the screen brightness will not return to the issue
Fixed font size on the 14th, the skin is often the skin menu, text display issues will be misplaced
Sogou input method fixes the use of everyday sounds can not search the lyrics and pictures use the Paste function of the problem
Repair automatically download pictures of the border, open the auto-hide the visual effect, visual effect does not show the problem
Fix font set is too large, the English words have been split display problems
Repair # + under the tag files, you can not issue a continuous mark
Repair off visualization, the switch will appear black background visual problems
Repair White Melody II fast-forward rewind, the reflection of part of the problem will be flashing
Repair Word Graph search results more than 1, when the cursor moves to the last line, the cursor will move up a line problem
Repair manual to change the list sorting, the picture associated with the problem would be confused
Repair screen background shows that built-in picture, picture of the problem will be tensile deformation
Fix custom directory, the path at the end do not enter "\", the saved path is not the complete issue
Note : IF U GET System Error Install Patch 4 run.sis Inc Attach
دوستان عزیز برنامه با 16 تا صفر (0000000000000000) رجیستر میشه اگر در اجرای برنامه با system error مواجه شدید فایل patch را که همراه برنامه هست نیز نصب کنید
