پاکسازی دستی و اتوماتیک رم گوشی با CellPhoneSoft RAMblow v1.0 S60v3 v5
6,787
29,884
CellPhoneSoft RAMblow v1.0 S60v3 v5 SymbianOS9.x Repack Cr@cked-FoXPDA
دوستان این نرم افزار قابلیتهای خیلی جالبی برای پاکسازی رم شما و افزایش سرعت گوشی داره.
یکی از قابلیتهای جدید برنامه پاکسازی حافظه رم به صورت اتوماتیک در زمان پر شدن رم و همچنین در زمانی که گوشی به صورت بیکار هست. یکجوری دیفراگمنت رو هم انجام میده!
RAMblow aims to maintain a healthy amount of available memory, or RAM, tohelp running the phone smooth for a long time.
The application provides automated memory management, as well as manual termination of runningprograms.
The memory boost feature can blow RAM up to amounts neverbefore seen.
RAMblow is very simple to use, just let it run in thebackground, and you will never again find your phone lacking memory.
Major features:
*.Unattended and manual management of running applications.
*.Maintaining a healthy amount of free available memory for smooth operation of the phone.
*.Memory optimization for executing large programs.
*.Automatic memory cleanup after set idle time.
*.Examination and manual closing of unwanted programs.
*.Reporting the results of memory cleanup.
NOTE
DisableOpen4all In ROMPatcher+ Or Install ROMPatcher+ In Drive Z: with PNHT Method
