سوئيچ كردن بين برنامه هاي در حال اجرا aRed v.2.2 S60v3 S60v5 Symbian 9.x
6,774
29,828
aRed v.2.2 S60v3 S60v5 Symbian 9.x Unsigned Freeware
نرم افزارaRed v2.2 نرم افزاري كاربردي مي باشد كه به وسيله ي آن مي توانيد به راحتي در ميان برنامه هاي درحال اجرا در گوشي جابجا شويد
Small programm for cyclic switching between running applications by pressing the Red button. In addition to the Red button, you can select other keys as hot: PTT (E50, 6290), Camera (6120c, N79), Gallery and MM-key (N82), Mail (E61) and Silent (E65). aRed works in background and doesn't appear in the tasks list.
Key features:
* §³yclic switching between running applications by pressing the Red button;
* Select other keys as hot (PTT, Camera, Gallery, MM, Mail, etc.);
* "Don't show" option, for disable switching applications, such as: Standby mode, Contacts, Gallery;
* "Long press" option, for choice action by long pressing the hotkey (run Connection manager, End task);
* Ability to switch between applications when keypad is locked;
* Works in background. Not shown in the Tasks list;
* Autostart.
What's new:
* Removed standart keypad lock for lock/unlock option
* Fixed bug with pressing "*" key and crash app
* Added TaskWindow option for "Shot press"
NOTES:
Before installing this version you must remove the previous! Switching when the keypad is locked and backlight setting is guaranteed only when using the standard lock!
