aRed v1.9
Small programm for cyclic switching between running applications by pressing the Red button.
Applications are switched cyclically.
Convenient, no need to run every time taskmen.
The application does not hang in the tray.
There is a customizable Autorun.
May include switching applications when the keypad is locked. In this case, you can adjust the backlight to include or not when you press the hot buttons.
When calling the red button works as expected, ie, completes the call.
?Ranoobraznye setting long pressed the hot buttons:
-nothing
-system function
-close the application
-launch the application
ABC-sticking
Can be excluded from the cycle switches:
-all applications
-running applications
Changes in version 1.9:
-Fixed work buttons, camera (n79) and mail (e61)
-the menu is no longer running application icon next to the icon aRed (thanks to an unknown Chinese for a hint in a letter to the soap)
-once again rewrote the job options system function (in my n82 works perfectly).We try.
[!] (Switching when the keypad is locked and the backlight setting is guaranteed only when the standard block)
[!] Before upgrading MUST uninstall the previous version.
-nothing
-system function
ABC-sticking
-all applications
